headlamp...keeps blowing
gkf9 Oct 3, 2007
  1. gkf9
    gkf9 Member
    256
    Took my car to the garage next to work for hl bulb changing...charged me £42.00 (after searching on here i now no how to change) Few days later gone
    again...took it back said it could of been a dodgy bulb so replaced free of charge with another one...again went after 4 or so days...took it back today and he said his electrican would have a look...im now on my 3rd bulb which
    he has replaced free again..but said its a different make and a more expensive one.
    The electrician couldnt find anything wrong ,said it was getting the normal 12v so will see how this latest bulb goes?
    If it does go again im going to have to take it to the stealers which im very reluctant to do!! Some one did mention it might be the voltage regulator? As anyone had this go before? My car is a B6 A4 TDI
    Thanks for any info or help
  2. jase0851
    jase0851 Member
    789
    vag-com your car see if there is any faults on the electrical system
  3. gkf9
    gkf9 Member
    256
    Thanks but i dont have vag-com unless i go to the dealers.
  4. dan_b
    dan_b Member
    263
    Could be something fishy in the light cluster - any bits of loose wire or signs of corrosion around the bulb area ?
  5. gkf9
    gkf9 Member
    256
    Not sure cause the garage fitted it...sure they would have said something if there was any rust?
  6. dan_b
    dan_b Member
    263
    You'd like to think so, but...
  7. gkf9
    gkf9 Member
    256
  8. Spacecowboy
    Spacecowboy Member
    367
    I think each headlight has its own 'ECU'. when they go, they blow bulbs. Speak to a specialists or do a search on here
