Head unit
laney Feb 6, 2012
  1. laney
    laney Member
    58
    Is it best to buy an aftermarket head unit or can
    You adapt something to take aux on standard
    Unit?
  2. aragorn
    18,579
    868
    Standard units a bucket of **** so your just as well replacing it.
  3. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    You can get a Connects2 box for about £30 which allows AUX in via the cd changer input
  4. Danman1
    Danman1 Thorough noob
    342
    19
    I had an after market head unit in my S3, replaced it with an original because it was better in my eyes. However the after market one is a Sony explod which had a 3.5 mm aux jack on the front. £40 if you want it. Like new, with wiring to go into an 8l a3/S3
    Dan
  5. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    I have one of these in my S3 - works fine, keeps the OEM look and the MP3 hides away in the glovebox.
  6. stumpy83
    stumpy83 one legged wonder
    90
    im looking for an OEM set to replace my pioneer, you can purchase a cable from ebay for about £9 for an aux ;)
  7. AndyMac
    9,832
    46
    Those cables are just a cable, which will be useless on its own, you need a box of electronics that simulate the CD changer otherwise the HU will just ignore the connection
  8. stumpy83
    90
    the lead im thinking dosent need any box it will connect via the blue mini iso socket at the back of the unit which will give you a direct aux
    and you control the music via your external device
  9. AndyMac
    9,832
    46
    Ahh the magic lead yes I forgot about that one. And how do you select the mini blue ISO socket as a valid source with no CD changer connected to it?
    As said you need a Connects2 or similar to emulate a CD changer so that the HU then allows you to select the CD input as a valid source
  10. stumpy83
    90
    well i know it works so thats ok for me ;)
    the stereo thinks its connected to a cd changer, the apporpriate pin is grounded which fouls the head unit to think its the changer then allows the (LEFT / RIGHT) input to act as an aux input
  11. AndyMac
    9,832
    46
    Wow think how annoyed Dension, xcarlink & Connects2 will be when they find out. All that R&D replicating a databus and all they had to do was ground a single pin!
  12. stumpy83
    90
    your very sarky!!!! and its the same with peugeot,
    do you know everything?
    im not gonna argue with you guru
  13. laney
    laney Member
    58
    One problem guys mine doesnt have a cd player, i like the unit thats in now so wanted to keep it but
    if to much hassle il buy aftermarket
  14. stumpy83
    90
    on the reverse of the unit is there a yellow / blue / green socket above the power / speaker iso??
  15. laney
    laney Member
    58
    just changing convo slightly, do you know how hard it is to fit face lift lights?
