Head light Remove how too......
pink.teg Jun 24, 2012
  1. pink.teg
    pink.teg Member
    170
    hi all
    is there an easy way to remove the head lights
    i want to take them off and clean the insides ,,got to be cheaper then buying new
    headlight units ....
    thanks alan :think:
  2. simon.m
    simon.m Active Member
    2,747
    2 screws on top and to at the back on the bottom bit hard to see but you only need to loosen them not take them right out
  3. quattrojames
    14,050
    575
  4. pink.teg
    pink.teg Member
    170
    Cool that ...thanks guys
    will be breaking them down for a good clean ,so they look nice and clean ...or stay dirty..
  5. quattrojames
    14,050
    575
    If you're going to split them try the Joey Mod guide on A4Mods.com.
  6. Bean5
    Bean5 kidney bean
    341
    its dead esy to pop the headlight out mate but ye, remember u only need to slacken off the back/bottom two screws, not out all the way as u will struggle to get them back in!
  7. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    I did mine over the winter and I found pouring washing up liquid in with some really hot water (not boiling) and give them a right good shake loosens majority of the **** off
    mine was really bad the water was black! on the plus side I could see after I did it!
  8. pink.teg
    pink.teg Member
    170
    Hi
    Done the headlight cleaning thing
    and sealed all up and back on car
    it just seems to mist up every time I turn them on now
    what to do !!! I've taken the back off and blown it with the hair
    dryer and it's ok ... Then I go for a drive with them on and
    it mists up again
  9. hades-
    9,481
    646
    you havent sealed them right
    or the back cover aint on correct
  10. pink.teg
    pink.teg Member
    170
    Nope im pretty sure ive sealed the lights up all around and the new seals on the back plates too
    but still mist inside ...
    may have too reopen and seal again .....
    another days work ....
  11. sorry to jump on a thread but on the subject of headlights can the metal clips that hold the bulb covers on be replaced? two of mine have gone awol
  12. pink.teg
    pink.teg Member
    170
    Yep ,,, best thing to do there m8
    is look on fleabag " breaking Audi A4s "
    call them and see .....
