Head lamps misting up???
kazino21 Jun 23, 2004
  1. kazino21
    kazino21 Member
    41
    Hi guys I have a 2001 (51 reg i.e. facelifted newer headlights) with non-xenon head lights, I know that Audi's have a problem for misting up headlights and I would have thought that over time the chrome bits inside would degrade. I told my Audi dealer and they have said that they only replace the head lights when there is dripping and they will not replace it if there is just condensation. Are they lying or is have others had this problem? Please advise.
  2. speedyp
    speedyp Member
    123
    I had this with fog lights & they said that for all lights they only change if the water is dripping inside, rather than just condensation!!!
    Quite a common thing apparantly, especially TT head lights!!
  3. kazino21
    kazino21 Member
    41
    yes that is what they told me. But I talked to a VW dealer and he said that the chrome bits would be ruined over time is this true?
  4. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    If water is getting in, then yes!
    Rich
  5. kazino21
    kazino21 Member
    41
    so that means that condensation will damage it too right.
  6. Haris
    Haris Member
    58
    Eventually yeah..
  7. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    Only if it stays. The reflector will rust with water over time.
    Rich
  8. kazino21
    kazino21 Member
    41
    is there any way of getting audi to replace them under warantee, they have noted that there is condensation but that there was no dripping.
  9. richy
    richy Member
    892
    the way you could get around it is that due to them steaming up its causes the beams to fade and not work at 100% and so may cause an accident cos i cant see properly and so if i do i will sue audi due to the fact i noted the problem before hand...
    new headlamps thank you please!
  10. peteA3tdi
    peteA3tdi Member
    408
    if you have no beam image its a mot fail, you could tip some more water in them then they will have to change them!
  11. steve184
    steve184 Active Member
    1,138
    It does actually say in my new audi A3 manual that condensation inside lights is perfectyl normal and acceptable and doesnt consitute a fault!
