Head gasket done, but still! There's a leak :o
Priggy Mar 22, 2013
  1. Priggy
    Priggy New Member
    20
    Changed my head gasket last weekend with the typical cuts and bruises, many stops for tea and the occasional drive to halfords! (Needed the "ribe" tool to remove head bolts! 27 pound thanks audi ;))
    But it turns out I still have a god damn leak!! Im guessing this must be the water pump, either boiling? The water and therefor it's disappearing on me, or generally have a leak coming out of it. But I've never changed a water pump on an a3 and was wondering if anyone could give a few pointers to minimise the time it will take. It's suppose to snow soon so will have to work fast haha. I've got a replacement pump which oonly cost me 29 pound surprisingly.
    Is it a quick job or will I have to spend alot of time fiddling with the cambelt etc.
    ive got a audi a3 1.6 SE
    any help is appreciated cheers!
  2. Danno57
    Danno57 Member VCDS Map User
    44
    I would purchase some UV coolant leak detection dye along with a UV torch before throwing any more money at parts, then hopefully you can pinpoint the leaks location when the engines up to temperature. As for the water pump you might as well do the cambelt, tensioner etc at the same time. It's quite a big job.
  3. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    did you have the head skimmed? did the old gasket have signs of where it had blown?
  4. A3_130
    A3_130 Member
    85
  5. Broken Byzan
    13,237
    465
    The 1.6 is common to develop cracks, did you get it pressure tested and skimmed?
