Head Casket Help Needed ASAP!
ScottishA4B9 Jun 19, 2011
  1. ScottishA4B9
    ScottishA4B9 Well-Known Member Team Daytona Audi A4 S-line owners group TDi saloon
    3,005
    764
    Hi All,
    My GF has a '99 Mk2 Fiat Punto 1.2 8v and the Head Casket has gone on it.
    I have seen replacement parts on eBay for £7.99.
    Does anybody know how much roughly it would cost to get a head casket replaced?
    Hope its not too much as the car is only worth around £900-1000.
  2. scott s3
    scott s3 New Member
    where are you based? are you a mechanic?
  3. ScottishA4B9
    3,005
    764
    Im in South Wales mate. I would have to get a mate to do it or a garage as Im no mechanic!!!
  4. scott s3
    scott s3 New Member
    ok well heres some advise, the labour to remove and refit will be about £120 as the 8 valve engine is very easy to work on, second thing is you MUST get the head skimmed as headgasket failure causes the head to distort and failure to skim it will just result in the same thing again soon after rebuild. if your saving pennys you can save the antifreeze and run the cambelt again but treat it to an oil and filter change, i would do it but im over in manchester.... good luck buddie
  5. ScottishA4B9
    3,005
    764
    Thanks Scott!
