head bolt tool and timming belt tool
s3gazz Aug 14, 2012
  1. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    can anyone post a link of the correct head bolt tool and the timming belt tool to slaken it off the timming belt please iv look on ebay but i just dont no wich one is right and dont want to buy the wrong one thanks.
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
  3. s3gazz
    1,383
    105
    or thanks mate and just got told they was a tool the slaken it off thats all never mind
  4. <tuffty/>
    21,679
    4,106
    I assume this is to replace your current head with the large port one you have? If you are using a new belt (advisable) then just cut the old one...
  5. Andrew@A.L.D
    3,879
    617
  6. s3gazz
    1,383
    105
    thanks tuffty ill just cut it then and take it i wont need the tool or will i need it to get the new one on by slackening.
    thanks for the editing tuffty forgot how to post pic lol
  7. <tuffty/>
    21,679
    4,106
    You will need the tool Andrew posted a link to... thats so you can re-compress the tensioner damper... ideally you need the pin that normally comes with a new damper or... I would be personally changing the damper if you haven't had it changed that you are aware of...
    They don't typically get changed as part of a cam belt change as for some reason Audi deem it unnecessary... however... the dampers have a habit of getting tired and will loose tension causing the cam belt to slip teeth and of course nuke the engine as a worse case...
    Considering the level of work you are about to under take I would buy a new one...
  8. s3gazz
    1,383
    105
    Ok I'll get the tool ordered tuffty.
    Dampers where's best place mate that don't cost a tone
  9. <tuffty/>
    21,679
    4,106
    I got mine from GSF... my last one was an OEM one with the logo's machined off... still £40ish though...
  10. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Ive got both tools numb knackers ...... :p
  11. beachbuggy
    1,931
    202
    N
    Never knew that tool existed, learnt something .
    I use my brake calliper rewind tool in reverse. Fits over and then winds in to compress the damper . I guess it's a solution if any one doesn't have that specific tool. It also works when the tensioner is still installed on the car. Put it between the tensioner end and camshaft pulley and gently wind it out will compress the damper enough to get pin back in. Again just a tip, saves trying to get the thing out.
  12. Andrew@A.L.D
    3,879
    617
    You can make you own with a longish M5 bolt with nut and a large but thick washer, Its hard to reach so i have a 8mm spanner thats been bent at a 90 deg to get to it when its in and wound down
  13. s3gazz
    1,383
    105
    thanks guys great help.
    dave ya a star mate thanks.
    tuffty ill ring gfs and get the part ordered then just a damper.
