Hazard Issue
Heitor Dec 27, 2009
  1. Heitor
    Heitor New Member
    Hello guys!
    I have a 8L and I'm having problems with my hazard lights, the turn signals work fine but hazard doenst sometimes it blinks one side sometimes nothing at all. Does anyone have a clue of wtf is happening??
    Regards!
  2. noddys3
    noddys3 Member
    99
    Mine is the same matey, they have a relay built into them and always stick, euro carparts say around £26 odd +vat mate for a new one!that's what I've done!
  3. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Use the search tool, look for hazzard relay.
    Cheers matt
  4. Heitor
    Heitor New Member
    I did some search but the thing is usually u have a indicator problem with the hazard. In my car I just having problems when the hazard is on...only one side blinks or sometimes there's no blink at all..
  5. Broken Byzan
    13,237
    466
    There are 2 relays built into the hazard switch unit, one works the repeaters, and one works the hazards. Replace the switch and your problem will go away.
    Good luck
  6. Effect
    Effect Member
    469
    I have a brand new one that was used to try and fix a different problem that i was having (unsuccessfully I might add).
    Yours for the princly sum of £20 (cost me £28 + vat)
    James
  7. metricspaces
    metricspaces Member
    661
  8. Heitor
    Heitor New Member
    Can u ship to Brazil? How much?
  9. Heitor
    Heitor New Member
    I found the electrical diagram for the hazard relay...if it helps someone...
    I tryed to fix by myself, yesterday, and I got one side of the hazard working again but the other side still lazy....
  10. Effect
    Effect Member
    469
    Yes I can
    Postage will be about £5
    Regards
    James
  11. carlparkin19
    carlparkin19 New Member
    hi there i have been reading a couple of posts, and not sure what my problem can be. the hazzards come on by themselfs and unlock the door, also if you get in the car and start it the light that says passanger air bagg off near the interior light flickers on and off, some times you can keep the hazzards off but others you cant any help out there if it is just the hazzard switch anyone got a new one or no where best place to get one is.
    cheers carl:blackrs4:
