Having problems with my cabriolet
m.c. May 22, 2012
  1. m.c.
    m.c. New Member
    2002, 2.4 v6 Petrol, B6 Cab.
    With it being a nice day today i decided to drop the roof for my drive home at dinner time, got out, opened the boot to get somthing out, locked the car, no probs.
    Went out to go back to work and the door wouldn,t open (unlock or lock) with the fob, the electric windows and mirror,s will not operate, the roof will not close (had to close manualy), no indicaters or reversing lights and fog lights, electric seats won,t work.
    I have a smart roof mod fitted aswell, if that is of any use.
    Did a scan and these are the faults that came up, i know about the Air injection system bank 1 and 2.
    Any help with this would be great.
    6 Faults Found:
    17947 - Clutch Pedal Switch (F36)
    P1539 - 004 - Implausible Signal - Intermittent
    17831 - Secondary Air Injection System; Bank 1
    P1423 - 002 - Insufficient Flow - Intermittent
    17819 - Secondary Air Injection System; Bank 2
    P1411 - 002 - Insufficient Flow - Intermittent
    18010 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 008 - - Intermittent
    18043 - Powertrain Data Bus
    P1635 - 008 - Missing Message from A/C Controller
    Readiness: 0000 0000
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Component: Innenraumueberw. 0211
    Coding: 00001
    Shop #: WSC 00000
    No fault code found.
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186
    Component: concert II GRO 0008
    3 Faults Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    49-10 - No Communications - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    00466 - Control Module for Steering Column Electronics (J527)
    End ---------------------------------------------------------------------
  2. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
    try lookin at your battery.... you might need new one
  3. m.c.
    m.c. New Member
    Thanks, but it is a new one.
    It seems to have sorted it,s self out but now the roof won,t open, i,ll have a good look today on my day off.
  4. vr6gordy
    2,826
    191
    checked your earth lead from battery ?????????
