Having my turbo replaced i need help with a question please....URGENT
ondalow786 Jul 28, 2013
  1. ondalow786
    ondalow786 New Member
    14
    URGENT!!! ******
    CAN SOMEONE HELP ME, SINCE IVE HAD A RE-MAP DONE ON MY AUDI A3 2.0 TDI 140BHP 2008 MODEL BY AWSOME GTI.. I HAVE STARTED TO HEAR A POLICE SIREN FROM MY TURBO. DONT GET ME WRONG I HAVE LOTS OF POWER I CAN FEEL THE 180BHP POWER AND ITS GREAT, BUT THIS SIREN IS GETTING LOUDER AND LOUDER.
    I SPOKE TO AWSOME THEY ADVISED ME TO HAVE MY TURBO REPLACED. I HAVE A FEW QUESTIONS CAN SOMEONE ANSWER THEM IF POSSIBLE NEED TO KNOW URGENTLY... TA
    1) CAN I REPLACE MY TURBO WITH A MORE POWERFUL TURBO I.E 170BHP MODEL TURBO CHARGER?
    2) SHOULD I REPLACE THE TURBO OR RECONDITION IT?
    3) WHAT WILL BE MY CHEAPER OPTION?
    IT WOULD BE GREAT IF SOMEONE COULD HELP ME OUT - MY REG IS : US54MAB
    THANKYOU
    SAMMA
  2. Sevv
    Sevv Pushing the limits..
    1,321
    118
    in relation to question 2-3 replace it don't recondition it..i've personally heard to many issue with reconditioned ones... even awesome gti themselves told me not worth reconditioning...
    for question 1 not entirely sure another member can possibly inform you as i have a TFSI not TDI... it may be feasible though... but not sure if you'd have to remap again...
  3. ondalow786
    14
    Thankyou for answering some of my questions... i appreciate your time.
    can you recommend a place to buy a new turbo from? as i dont want to pay nearly 900 pounds for a turbo,
    is a garrett turbo any good?
  4. TDI140
    TDI140 Well-Known Member
    1,623
    174
    if you want bigger turbo you need to buy a hybrid turbo the 170pd isnt a direct replacement but it had been done and does make good power with the right mods
  5. Patrick_c99
    Patrick_c99 Member
    198
    Garret is what is on your car at the moment. Car parts for less do a oem turbo but personally I would go the hybrid route as they are designed to take more power so will last longer.
  6. ondalow786
    14
    do you know the part number and where can i get this hybrid turbo from for my car?
    will i just need a hybrid turbo charger or other things as well to make it fit in the car?
  7. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    midland turbos are very good for reconing your turbo..
  8. Patrick_c99
    Patrick_c99 Member
    198
    I'm afraid I don't no the part number as I haven't fitted one myself. But amd Essex are good for information. You also need to change to oil feed pipe aswel plus exhaust system to allow extra gases to flow.
  9. ondalow786
    14
    Putting a hybrid turbo sounds expensive. As I have to do further more mods on it to accommodate the hybrid turbo.
    I'm in Manchester can some one help and sort my problem out... I'm sooooo confused!!!
    Help!!!!!
  10. smurfworth
    smurfworth Well-Known Member Audi S3
    1,906
    528
    You don't need a new turbo until its screaming and people in the street turn around thinking its a police car.
    Until it reaches that level of noise, drive on.
  11. ondalow786
    14
    I can hear the police siren in the car... And it loud when I crack the windows down
  12. smurfworth
    1,906
    528
    It's loud as in, you can hear it in the next street?
  13. hades-
    9,480
    646
    send your turbo in to have it hybred
    AET 1 of many who i always use and never had a problem in over 30 turbos from them
    hybred and oem
  14. ondalow786
    14
    No, u can't hear it in the other street...
    It's not that loud. Yet
  15. ondalow786
    14
    What's AET1??
  16. hades-
    9,480
    646
    AET one of many turbo places
    google it its a company
  17. ondalow786
    14
    Ok I will do.. And they will recon my turbo?
  18. NHN
    29,295
    1,701
    Depending on your engine code, I have a brand new turbo here boxed for sale, standard as yours.
    We maybe able to change it in Manchester aswell.
  19. ondalow786
    14
    Amazing!!!!
    How much is it gonna cost me?
    As awesome have quoted me £850 including a new oem turbo...
    I really need this turbo dobe
  20. NHN
    29,295
    1,701
    I very much doubt that's including a new oem turbo fitted with new gaskets, nuts etc.
    I would check if that is with brand new or recon'd & includes vat as I'm suspicious of that price.
    PM for a price mate.
  21. ondalow786
    14
    I've just pm'd u
  22. TDI140
    1,623
    174
    i beg to differ i put mine on dyno had no screaming what happens turbo smashes to peices the explosion was so bad metal peices were found all the way up into the maf, so replace asap dont wait for it to get worse, hybrid is expensive but worth it if your keeping the car for while, mine was £1000 but milltek was £855 then i fitted new intercooler also forge hoses, catch can, so many mods but i had these all done before i knew turbo was going to blow up
  23. smurfworth
    1,906
    528
    See, mine was screaming so loud you could hear it in the next street away. There was no play in the shaft and no contact between the turbine and the casing. However, these turbos whine ever so slightly normally, and people come on here and are told to replace it because it whines. For all you know it could last another 60k on that whining turbo.
  24. TDI140
    1,623
    174
    Its bearing becoming loose and as soon as they give way the shaft will moves and compressor wheels will hit the casing an dvend if your lucky, my turbo the shaft snapped clean off and smashes into a million peocesewhilst spinningand ended up everywher which is why you should change it. I had to change a boost hose due to the metal peices shreading it, so dont wait and just have it done as it will just end up costing you more and more if you wait for it to blow up
  25. TDI140
    1,623
    174
  26. ondalow786
    14
    Hmmmm
  27. Patrick_c99
    Patrick_c99 Member
    198
    I've done 40k with my turbo whining like a police siren and its still going fine 😃 you can get a garage to remove it and inspect it. As if it doesn't need replacing your wasting money.
  28. ondalow786
    14
  29. TDI140
    1,623
    174
    Just replace it for hybrid its so much more fun
  30. ondalow786
    14
    I think the hybrid turbo is costing me too much..,
    I've booked it in for a new oem turbo replacement.
    Also should I get a blow off valve placed? Would that help take the pressure if the turbo as my car has been remapped ?????
    Can someone answer that please???
  31. Tomwebb
    Tomwebb A3 2.0 tdi s line 170
    60
    I'm in the exact same boat as you! In thinking of getting a recon unit with 2 year Warrentee from essex turbo for £400. But after seeing what people say about recons it's making me think twice... I really don't want to pay a fortune. Do you REALLY need to add the extras when getting a hybrid, can't it just be mapped down to work nicely?
  32. Sevv
    1,321
    118
    instead of changing the whole exhaust system maybe you can just to the cat back and DP... should save you 400quid
  33. ondalow786
    14
    blow off valve??? yes or no????????
  34. TDI140
    1,623
    174
    Blow off valve on a TDI ? It doesnt exsist mate and the crappy ebay ones look and sound like S*** leave blow off valves to the tfsi's
