Having car remapped again next week is it safe to run 1.88 bar ? Help please
TDI140 Sep 18, 2013
  1. TDI140
    TDI140 Well-Known Member
    1,632
    175
    Having car remapped again next week wanting to know if tunning 1.88 bar is safe on stage 2 turbo dynamics hybrid when you ask them there lost and dont know anything so its pointless speaking to turbo dynamics about mapping, im having it mapped for a uprated clutch and will have that fitted as soon as it starts slipping so i can be sure of what clutch to order, next year plans i will get s3 cooler and hard pipe kit from darkside developments with EGR delete around a 5hour job they said so ill hang around there and drive back same day
    basically want to know your views on having my car remapped to 1.88 bar and whether turbo is good for it as its running 1.82 bar at this moment in time
    thanks in advance
  2. TDI140
    1,632
    175
    Anyone ?
  3. MAD_Adamski
    MAD_Adamski Member
    344
    I personally don't think you'll see much gains from 0.08bar of boost i'd leave it as it is tbh. Maybe look at it once you've done the work you want to do!?
    I have a cr170 dpf I am in the process of fitting a egr delete, darks idea downpipe and Milltek exhaust and remap with this I should see 200-220hp this should be perfect I don't think I'll need hard pipes or a cooler. I just wanted mine a touch quicker as it's my daily car. I have my cosworth to go fast. :)
  4. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,286
    626
    Turbo Dynamics may not know anything about mapping, but they should tell you at what boost they warrant the turbo to, so i'd speak to them again. As said, the extra boost is negligible, infact the boost control isn't that precise so it's essentially no different to how it is now.
    Rick
    tdi-man likes this.
  5. TDI140
    1,632
    175
    darkside decelopment remap there gt1756 turbo to run 31psi which is 2.1bar with all my supporting mods thats very high boost, i gave turbo dynamics a call and thy said that people have ran 1.9bar to reach the estimated 240bhp but not got there max they have seen is 230-235 so ill be happy with that afterwards ill be getting s3 cooler next year and EGR delete will be bought and fitted before i have it mapped will post results after the work
    Adamj likes this.
  6. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    TDI140 likes this.
  7. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Why not delete EGR before this next map?
  8. TDI140
    1,632
    175
    i asked them if warranty will be void they said no if i mapped it to 2bar it is too high they say turbo could be perfectly capable of runnig. That but warranty is void so im going to try 1.88bar like you tdi-man
    jonathaan ive said in an above post that i will have egr delete done before the map
    is the allard and darkside developments one the same egr kit or is one better than the other also seen the cooler deleter plug darkside do so might get thats and turbo blanking plate aswel
  9. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    You said you was getting it done next year?
    And you getting a new map next week?
    All im thinking is why not blank EGR off with a plate instead of using the kit, if its the same on the 140 as to 170 i have a EGR blanking plate i can send you.
  10. bigal23
    bigal23 Member
    208
    Just go 2bar how would they ever be able to prove you ran boost over the warranty spec
  11. TDI140
    1,632
    175
    2.0bar is too high its not the turbo blowing up its the hassle of returning it and then getting another off then then not counting the labour costs 1.88 is what ill try and then if the turbo is good with it and not over spooling might push it to 1.9bar when the s3 cooler is fitted, bigal did you have the darkside budget kit fitted ? Or is that another member ?
  12. TDI140
    1,632
    175
    Also what EGR kit have people had fitted ?
  13. tdi-man
    1,783
    64
  14. TDI140
    1,632
    175
    thanks pal appreciate it, will orderdarkside one with cooler deleter and blanking plate for manifold donit next week before remap
  15. Rick @ Unicorn Motor Dev.
    1,286
    626
    You don;t need any kind of kit. You simply blank it off.
  16. bigal23
    bigal23 Member
    208
    yep its me who had the kit fitted
  17. TDI140
    1,632
    175
    i want it to look nice and neat not just a blanking plate i want tge cooler removed and also blocked off from the manifold so i can get rid of the long metal egr pipe so darkside will sell me the complete kit also instructions to make sure its done properly
  18. TDI140
    1,632
    175
    thought it was you, just wondering your budget turbo kit contained the GT1756 turbo ? Which is pretty similar to my ine internally
  19. bigal23
    bigal23 Member
    208
    not really mate hybrid is a lot smaller in everyway still inducer on yours should be 38mm exducer compressor 52mm
    turbine inducer 43mm turbine exducer 38mm
    mine is 41.5mm 56mm 50mm 41mm
    makes a lot of difference you really need to go have a drive in a car with a darkside kit fitted
  20. TDI140
    1,632
    175
    Compressor is 56 on mine thats all they told me lol i get what your saying though by hybrid is much smaller, my mate had ko4 hybrid on his s3 1.8t was 330bhp now just fitted GTX2871r turbo with manifold and inlet manifold with porsche 911 turbo fuel pump hes running 430bhp and will be remapping it soon as hes allowing turbo to run in
    Wish i had just bought darkside turbo set up but. Not going to change turbos now too much hassle and unnecessary expense lol
    are you going to be getting 1287 race injectors and s3 cooler fitted to yours ?
