have many of you fitted a b7 MFSW?
rob irl tdi Feb 23, 2011
  1. rob irl tdi
    rob irl tdi Member
    240
    Just wondered if you need to re-wire the airbag?
  2. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    completely different wiring: it's possible, but get a professional to do it.
  3. rob irl tdi
    rob irl tdi Member
    240
    No pro's in Ireland. If Shark opened here they would make a fortune
    I know the wiring is different on the slip rings thats grang, but the airbag i'm not sure
    Anybody have a how to?
  4. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    B7 wheels have a dual stage airbag, B6s have a single stage airbag controller.
    Wiring only the second stage is not proven to work in an accident, wiring both in parallel can make the airbag light come on and isn't proven to work in an accident.
    How much do you NEED an B7 MFSW? And how would you, your family and your insurance company react if the airbag didn't work properly?
  5. mlody
    mlody Member
    184
    I fitted my B7 mfsw myself, no airbag faults, I changed the slip ring. the Mf is not working yet because I need the B7 module but will get that sorted soon as well. I can do it for you if you want, Im located in Ireland :O
  6. cheech
    cheech Member
    62
    i fitted mine myself all FULLY working no errors any where :)
    pretty easy with vcds and the forums
    cheech
  7. will89
    will89 Member
    357
    Personally i wouldn't fit one myself, you say it is fully working yet you can't test the airbag?? Is it worth risking it?
  8. quattrojames
    14,068
    585
    You only get one chance to test an airbag!
  9. mlody
    mlody Member
    184
    If the airbag wasn't working properly then Id suppose it would show an error?
  10. will89
    will89 Member
    357
    Nope, you won't know until it tries to activate it. And that is only going to happen when you hit something or someone hits you.
  11. rob irl tdi
    rob irl tdi Member
    240
    So what way did you wire it?
  12. mlody
    mlody Member
    184
    bought the slip ring and fitted it lol and it works... The mf doesnt work yet because I need the module thats under the slip ring. It has to be a B7 one if its a b7 sw
  13. Chris79
    Chris79 On my 3rd A4! RS4 next???
    159
    I have a b7 mfsw for sale if anyone on interested. £100
    Chris
  14. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    Has no one tested duel air bag on a single air bag set up?
    Or at least been in a crash?
  15. will89
    will89 Member
    357
    I have seen pictures of accidents where people have fitted a mfsw from a b7 and the airbag hasn't gone off!
  16. will89
    will89 Member
    357
  17. ScottD3
    15,165
    1,124
    That failed then, but how was it wired up, was the speed enough to active a standard air bag or what the crash impact enough to activate it?
    But has any one taken the bits to one side and tested on a bench to make sure?
