Have i blown my turbo?
Audiman99
U.K.
Hi, my car seems to be running in limp mode, the turbo doesn't seem to be working, theres smoke coming out of the exhaust and from the back of the engine bay when i rev it with the bonnet open. Theres a metal against metal noise when I'm driving, maybe turbo blades inside turbo? Cars on 98k and on its first turbo. Theres no error on dash and no obvious lose pipes that i can see. I will admit when it went i was reving it rather hard.
Any ideas guys?
Allan
VAG-COM Version: Release 311.2-N
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 J
Component: 1.8L R4/5VT 0004
Coding: 10710
Shop #: WSC 78385
WAUZZZ8LZ1A079589 AUZ7Z0Y1733403
5 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
P1455 - 35-10 - - - Intermittent
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-10 - - - Intermittent
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-00 - -
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 980 L
Component: AB-KOMBIINSTR. VDO D12
Coding: 01444
Shop #: WSC 10001
Address 22 -------------------------------------------------------
Controller:
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 16238
Shop #: WSC 06435
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 55 -------------------------------------------------------
Controller:
End -------------------------------------------------------
Where is Kent are you?
Drop the intake pipe off before the manifold and rev the engine, you'll soon know if the turbo is gone or not
I'm in Dartford m8, Ive got a guy coming out to look at it at 5pm. Whats the easiest way to access the intake pipe, is it from underneath the car?
its probably under the engine cover, if you have someone coming out then maybe wait for him.
Sounds to me as if your turbo has indeed shat out its innards. The noise you describe is it like a dentist drill?
Not really dentist drill, but def like something rattling away inside something metal. But only when reving not when driving along slowly. I dont have the engine cover on atm, the pipe your talking a4quattro, is it attached to the air filter as well as turbo? The one that sometimes collapses under pressure?
ive also got yellow gunk on the dipstick and under the oil cap!
yeah thats the best pipe to take off as then you will be able to see the turbo fin's with out the engine running as the last thing you want to do is keep running th engine incase it swallows some of your knackered turbo.
i feel like crying, i lost my iphone at the wkend without insurance, had to put my dog down sunday morning, my cars fuked! and now liverpool lost! I must be cursed! :((((((((
Could be worse, I'm a Chelsea supporter.... 3-1!
The pipe i was suggesting taking off is the turbo charge pipe not the vacuum pipe. Take a pic of your engine and I'll draw an arrow where it is.
chin up mate, it may look bad now but it still could be something less serious - possibly and fingers crossed for ya
heres an engine bay a4quattro.
off topic, thats a good plan double jubilee'ing the front left samco to the rigid pipe
Take the blue samco in the bottom right off, where it meets the manifold, rev the car and you'll feel a huge whoosh of air coming out of it if the turbo is still functioning.
watch for flying objects doing it that way though, id take the top left one of and see whats going on right at the turbo
Flying objects? Like what?
Personally i'd rather see any flying objects come out then go into the engine and totally screw it.
flying odjects like broken turbo, id rather not see flying objects or run the risk of ruining my engine by running an engine with a posible failed turbo, thats why id remove the tip and check the turbo at the turbo with out even having to run the engine risking damage
Very very unlikely anything would make it as far as the intake manifold anyway, as the intercooler would stop it. Normally the turbine fins might end up out the tailpipe but the chances of him getting hit by anything from the charge pipe are virtually nil.
Jonesy, bring your car round mine and I'l have a look at it for you. I'm near bluewater.
i wouldnt move the car if you suspect turbo failure, you can still get small parts of turbine blade pass through the intercooler plus the amount of oil that can pass through will carry large amounts of metallic dust through the intercooler and can score the bores!
just take a pipe off from the turbo so you can stick a hand or finger in( engine switched off, keys in your pocket!!!) and try and turn the turbines, if not turn or scraping sound its ******!
Hi guys, i haven't got round to looking at the car yet as been a very busy weekend and been using my mums car to get around. I'm off work tomorrow so will have a look hopefully gonna check all pipes and inside the turbo. I suspect the headgasket is going as well as there was gunk in the cap and dipstick area. Strange tho as i had a new head fitted last year!!!
Anyway thanks for offering to look at it A4Quattro if i have any trouble ill contact you. I may be able to source a turbo for £250. Quick question how hard are they to fit? Also the products that claim to fill cracks in the headgasket would you recommend them?
Allan
sht happens pal, objective of the game is how you react to the ****, e.g, negatively or positively e.g. i crashed my car into a roundabout 1 month ago (brake failure). airbag burnt 40% skin off one hand, gf dumped me been commuting on the train to work.....etc. but on the brighter side! Insurance company paid me off on the car, more than i paid for it! And im about to join the S3 club!
AND torres might score a hatrick tonight!
:ermm: please?
A4quattro i took of that hose on the bottom right and all it does is suck in air when rev'd? I also removed the top right hose which is connected to the air filter but there was no sucking at all from there. Ive checked all the hoses and none are loose or have come off. Its still producing loads of blackish/white smoke when rev'd and theres still a horrible rattling noise from turbo area.
Oh and theres oil everywhere near where you can fit the gearbox short shift thing plus some on the underneath of the hose on the bottom left, is that a bad sign lol. Plus my dipstick no matter how many times i clean it will come back out with yellow gunk on it!
I'm screwed ain't I?!
water getting into oil..... doesnt sound good normally
i think you need a garage urgently!!!
ok just got back from garage. They managed to get the pipe off the turbo and the blades are there but they said the bearing is gone and theres more movement than there should be so the blades are rubbing. Theres defiantly water getting into the oil but could this really be the headgasket when i had it done about a year and a half ago!
Also the noise i hear whilst driving badly sounds like a loose exhaust heatshield, but the garage reckon its the turbo, but i think its something else.
Anyone know what type of turbo i need to replace mine with. I know its a k04 but there seems to be different types and prices range from £200-£600 wtf!!
My cars a amk 210bhp 2001 if that helps
ty
i doubt that the head gasket has failed again its rare for the head gaskets to fail in the first place, i think its more then likely from where the gasket was changed before its easy to get water into the oil when fitting a new head gasket as there are oil and water ways next to one another.
also i expect it to be more a case of condensation build up, id flush out both the radiator and engine and start again with fresh coolant and fresh oil and see how it goes from there on.
did you have the head replaced when the head gasket was replaced previously and also why was the head gasket replaced before???
Hi when my head went before it ended up costing about £1500 from a Audi/VW specialist, cant even remember what they changed but was in garage for weeks! Thinking about it i have all the symptoms of a headgasket failure again. Non stop white smoke out the exhaust (but could be turbo), it overheated a few months back whilst in traffic. Mayo under cap and dipstick. What else should i look for?
I honestly give up.....
umm over heating smoke if not the turbo and your mayo does sound more like head gasket failure, take the coolant expansion tank cap off when its cold to see if it is still under pressure its not garentted to still be under pressure but if it is it looks very much like head gasket or craked head but as i said its not always still under pressure still, have you noticed coolant loss or oil loss??? id reckomed you take it to a garage though for some proper test before shelling out ££'s getting it fixed
Jonesy, not sure what garage you've been to, but since you are in Dartford, you could contact Dean or Adam from 4rings. They are based in Dartford and mobile. They know their stuff and will give you better advice after looking at the problems.
http://www.4rings.co.uk/
I've used them before and can't fault them at all.
just read your posts above, when the headgasket was done, maybe it wasn't done properly e.g skimming the head/block, not tightened to correct torque settings etc...
Smell the coolant, if it smells of exhaust then its headgasket.
Don't forget the turbo is cooled by water, and also lubricated by oil. If the internals of the turbo are cracked then they could be mixing in there.
The head might be a red herring, get the turbo checked/changed first.
The suction should come from the metal manifold, the whoosh/pressure should come from the hose itself.
There will be no pressure there, its before the turbo.
Sounds like the shaft has snapped in the turbo.
Could be because of the turbo shaft breaking or a waterway/oilway in the turbo being compromised.
not necessarily
Thanks for all the help, ill give those 4rings guys a ring and see what they say. Im praying the head hasnt gone, i really cant afford to have it fixed again. Ill keep you all updated once i know what the real problem is.
Again thanks for the help
Allan
4ring guys cant see me for 2 weeks as they are fully booked. But been offered a turbo for £300 with 62k miles, is this a good price?
sounds good to me then mate, no doubt there will be ways of checking how good they are or refurb costs, with 63k on i cant see it being badly.... wait for someone with a tad more knowledge before you commit
The best way to tell without fitting it it have a ****** good look.
All inside the compressor housings and oilways and check for anything untoward, and spin the shaft and check for any lateral movement in it.
