Have a Problem & Need help!!!
steve123a Mar 23, 2007
  1. steve123a
    steve123a Member
    240
    Hi
    I have a 2002 BAM S3, over the last couple of months the Lambda sensor in the downpipe seems to be removing itself! First time I took it to a mate and he diagnosed it as many other garages were saying it was a crack in the downpipe! Whilst I was with him he managed to get it back in place and tightened up, result I thought! Now 3 months down the line, was going round a roundabout last night and it has come out again.
    Has anyone else experienced this problem and is there anyway I can get some form of locktite to hold it in place?
    Any help very much appreciated!
    Thanks steve
  2. steve123a
    steve123a Member
    240
    I have been told by Tuning Werkes that it maybe the thread is knackered on the Downpipe? Anyone heard of this happening before, I hope its not as this sounds expensive!
    I was wondering if I get a washer and some form of sealant ( for exhausts ) whether it stands more chance of being held in place!
  3. HmanS3
    HmanS3 Member
    154
    could try getting a new collar tapped in to the Exhaust for the proobe to screw into seen it done with cross threadded spark plug bores so should work on this
  4. rickquattro
    rickquattro Member
    589
    The re threaded collar is the best long term solution but a temporary one is to re fit it, then lockwire it in place.
    Hope this helps.
  5. steve123a
    steve123a Member
    240
    Thanks for the advice guys!
  6. rich-s3
    rich-s3 Member
    56
    do you live anywhere near sheffield if so i could either helicoil it for you or put an insert in i got both kits for doing that
  7. steve123a
    steve123a Member
    240
    I live just south of london, I think I have sorted it... went to Audi to see if there was a washer which had come of when it fell out, apparently not!
    So I went to halfords and got some locktite and some washers, cleaned up the bolt added the washer and locktite and put it back in, have driven it around for a while today and it seems fine, the thread seemed ok and went back in very smoothly so don't think its threaded... hopefully the washer will give it a bit more bite!
    Thanks for the advice guys, appreciated!
  8. simch
    simch Active Member
    2,028
    Steve, take it to any local garage with a welder.
    So long as it seals in place, if its just popping out, just get them to tack a small weld on the side against the DP only needs to be tiny.
    When it needs to be removed (ie if you need a new dp) it will be smple enough to just grind off, or indeed proabbly torque off.
    take few mis to do only and will be a secure fix and take the worry out of the loctite fix!
    BTW if the seal is not tight, a bit of exhaust past on the rhreads will help prior to takcing ti in place. Or you can get some extremely expensive but extremely high temp silicone exhuast sealer which will do the trick too.
  9. steve123a
    steve123a Member
    240
    Thanks Simch will see how it goes for the time being and if it happens again will try out what you have recomended.
  10. ash_s3
    ash_s3 Active Member
    1,016
    I had a similar problem with the turbo to manifold bolt coming out all the time
    kept happening every week or so, in the end i got a brand new bolt and split-washer and used exhaust sealant on the thread and it hasnt bothered me for months now!
    I tried using locktite but the temperature of the exhaust just melts it so its useless!
  11. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    There is a fairly easy way to do this, but its not with loctite, which will not withstand the temperature of the exhaust.
    You could try using exhaust paste OR use a pin punch and hammer on the flange, this can if done carefully lock the component in place.
  12. steve123a
    steve123a Member
    240
    I may try that paste then if the locktite doesn't hold firm!
    Thanks again everyone
  13. satyak
    satyak New Member
