Has the s3 got lsd,s
s3dave Aug 5, 2010
  1. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    As above have we got limited slip diffs or dont they work like that with the Haldex?
  2. Dani_B19
    9,336
    392
    I dont think we have dave.
  3. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Haldex is a type of diff itself.
    Nathan
  4. Matt82
    Matt82 Active Member
    2,365
    you should have EDL
    electronic locking diff
    uses the abs sensors to detect slip then brakes the appropriate wheel to reduce slip.
    vag stuff has had it since 96-98 onwards. the S4 had it front and back so i bet youve got it too
  5. Matt82
    2,365
    every car i can think of has a diff, but hes asking about locking ones
  6. S3 Nattie
    1,599
    As Matt says, uses steering angles and abs sensor and yaw angle sensors (no sure if the S3 has yaw angle sensors) to distribute power between the front and rear and brake individual wheels.
    Nathan
  7. Matt82
    2,365
    s4 had an older fashioned torsen. 60/40 natural rear split and could shuffle power upto 90% in each direction.
    haldex is definately more fancy i suppose its questionable whether its more effective *shrug*
    as for LSD. you need a field and some donuts!!
  8. <tuffty/>
    21,583
    4,053
    Haldex 4WD is more tyre friendly than torsion/permenant 4WD, its pretty effective on most normal powered cars but certainly on higher power cars the performance controller would be the way forward as I can catch the thing out on occasion...
  9. s3dave
    10,110
    736
    it would be nice to have a controller to put the rears 100%..
  10. 1animal1
    9,978
    what for? donuts? :)
  11. s3dave
    10,110
    736
    for some drifting....
  12. 1animal1
    9,978
    oh dear :)
  13. s3dave
    10,110
    736
  14. jojo
    28,935
    3,588
    I think it needs to be pointed out that Haldex is a clutch and not a diff.
  15. s3dave
    10,110
    736
    yes true, but then it runs the diff
  16. jojo
    28,935
    3,588
    Hungry huh? Heard Dunkin' Donuts do many 'diff' flavours. lol
  17. Matt82
    2,365
    i thought haldex was a diff... operated by a clutch
  18. <tuffty/>
    21,583
    4,053
    Haldex is the electronically controlled hydraulic clutch mechanism that controls drive to the rear diff... you could (in theory) remove the haldex unit and connect the prop direct to the rear diff but wouldn't make for a very nice drive without a centre diff/torsion wotsit me-jigger...
  19. 1animal1
    9,978
    why thank you kind sir.....i might have to 'go' git me one those :)
    mmmmm Wotsits
    :whistle2:
  20. Matt82
    2,365
    right this is bugging me now. lets get to the bottom of it
    Haldex is a company
    Haldex Traction AB is a division of the Swedish manufacturing company Haldex AB. It specialises in the development and manufacture of All-Wheel Drive systems
    a 4wd vehicle can have a centre differential to apportion torque between the front and rear axles.
    what you call haldex is really a Haldex Traction LSC multi-plate clutch with ECU electronic control, acting as a center differential
  21. s3dave
    10,110
    736
    lol......................... i would get to the bottom of it but that is out of my league ....
  22. badger5
    9,543
    2,022
    as said its a clutch
    and to the op, no LSD fitted to S3 as std, although its posisble to add one to the gbox which would work on the front wheels
  23. Chlippo
    Chlippo Member
    679
    15
    what he said.
    you can have a LSD but i dont think its worth the $
    i think it is 1300$ what tt owner paid to have a LSD from i dont remember whatcompany
  24. <tuffty/>
    21,583
    4,053
  25. finesse
    finesse Active Member
    2,805
    good thread, great info
  26. S3KO4
    S3KO4 Member
    850
    The max torque the rear diff can handle I think is about 50% after that it would probably destroy itself. Hence the power distributions even with the performance controller you can not get anything above 50% to the back.
    The question is what would happen if you remove the front drive shaft? Silly I know but surely this would turn it into a RWD! As the ecu detects permanent slips on the front. ; )
