Has my S3 been rempapped??
m4nj May 10, 2010
  1. m4nj
    m4nj Member
    Hi All,
    Is there a easy simply way to see if my S3 has been remapped?
    can this be done via vagcom??
    - Manj
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Yep, check the air flow in g/s on measuring block 002 and that will give you a good idea. If mapped it should be around or about th 200 g/s mark.
  3. finesse
    finesse Active Member
    2,805
    vagcom can give you a rough idea
    210 S3 165g/s
  4. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    g/s readings can fluctuate though. Boost is where its at.
  5. sportstractor
    sportstractor Chugger
    2,709
    with him on this once, check block 115, and check requested boost on full load, should be about 2200mbar if its mapped, maybe more.
  6. ALPINE
    3,093
    make sure you read the right blocks tho ....:blush:
