Has anyone retro fitted rear parking sensors to the S3?
drfeelgood Oct 23, 2010
  1. drfeelgood
    drfeelgood Member
    225
    Driving around in all these courtsey cars with rear parking sensors has got me wanting them on my car. Is it possible to retro fit? Or is it a complete bumper unit which is required, rather then just that grey bit
  2. Prawn
    11,535
    3,475
    the grey bit can be bought seperately from audi with the pre cut holes for parking sensors.
    Same for an A3 too, you can buy the parking sensor specific lower valance for them too, although it's over £100 for the valance from audi!
    I've got parking sensors as an optional extra on my A3, and whilst I'd never choose to have them, they're SO handy!
  3. Nilz
    11,355
    894
    You can but standalone kits nowadays and make them look OEM, they are not that expensive either.
  4. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,577
    1,492
    C'mon guys - it's not a tank! Why do you need parking sensors on a little hatchback :)
  5. 1animal1
    9,978
    exactly.....you'll also notice that most cars with sensors have dented back ends, plus the **** end of the A3/S3 is the easiest car to place as the rear window is near enough the furthest point
    dont be a tart :)
  6. Chlippo
    Chlippo Member
    679
    15
    i wanted to have it on my S3 but the technician that was going to do it, didnt suggest it.
    he said that to be effective the sensors must be placed on the black part of the rear bumper, coz if he install it on the lower silver part (since my car is silver) they will be pointing a bit downwards which is not good for their efficiency...so they might start beeping way before you are close to hit anything (since the S3 is lowered too)
    anyways, its not just that i want to hear that beep beep when i am going backwards...i like the look of those sensors too and i was going to install it for the look more than anything else
  7. Chlippo
    Chlippo Member
    679
    15
    oh and that was about to cost me around 150$ including installation
  8. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    BEEP BEEP....wtf....Get the roadrunner soundtrack....:tocktock:
    YouTube - Road Runner & Coyote - Little Go Beep Brandt
  9. Chlippo
    Chlippo Member
    679
    15
    whatever you call it...but it is a beeping sound that you got from parking sensors and not mozart track
  10. s3dave
    10,110
    736
  11. rusty s3
    rusty s3 Member
    64
  12. doublem_1
    doublem_1 Member
    499
    If I get the genuine audi sensors for an A3 is it a simple job of drilling rear valance to pop the sensors in? And then where does the wiring plug into?
  13. banoffee
    banoffee Member
    124
    got mine from a Audi dealer and had already been fitted (not factory). very tidy job
  14. Chlippo
    Chlippo Member
    679
    15
    anyone get a picture of oem A3/S3 with rear parking sensors?
    it would be highly apreciated..i never seen one!
  15. Imteyaz
    Imteyaz 6th Gear
    535
    I considered doing this initially but changed my mind in the end...
    The genuine Audi rear parking sensors are larger in diameter than the run-of-the-mill Ebay variety, I was gonna fit the rear insert panel (with the cutouts for the sensors) and use a cheapo parking sensor kit but when I checked the hole diameter was about 1.5mm bigger than the sensors so I decided against it in the end - shame as it could have meant that the complete kit would come in at £75 (£50 for new rear insert, £25 for the parking sensor / kit).
    The insert made for parking sensors has a 'bulge' in it, allowing the sensor to sit at the correct angle / height - as Chlippo's technician pointed out, it would most likely not work correctly / effectively if they were mounted elsewhere.
