Has anyone performed a boost leak test on a 2.0t fsi before.
slim boi Feb 19, 2012
  1. slim boi
    slim boi Member
    35
    Hello as above after my list of faults and before i order my new DV i was going to do a boost leak test to see if i have any more leaks. I have read up that on the 1.8T u remove the PCV return hose is there anything like this on the 2.0T to remove.
    Cheers Slim
  2. hades-
    9,481
    646
    i had the garage do mine
    why dont you just remove and check if its ****ed
  3. slim boi
    slim boi Member
    35
    Just want to check to make sure nothing else is nackerd.
  4. OxfordRich
    OxfordRich Collecting Rings VCDS Map User
    112
    9
    As above, this never really got answered.
    Anybody got any simple step by step advice on what to block off when attaching leak tester to pressurise the intake? I'm running the Forge PCV replacement and catch-can too.
  5. Craig Cull
    Craig Cull Well-Known Member
    2,323
    1,156
    You block off the crankcase breather which is the only small pipe next to the pcv. Then pressurise and check for leaks
