Has anyone got original s3 suspension setup?
hank3944 May 26, 2011
  1. hank3944
    hank3944 Member
    146
    Can you measure the distance between the centre of the wheel and the start of the wheel arch?
    I have a sneaking suspicion that my rear may have the wrong springs or shocks :)
    My measurements are Front: 35.5cms Rear:37cms
    Thanks.
  2. Greig300
    Greig300 Member
    257
    Just measured mine for you mate rear 15cm....front 15cm.
  3. GeneralWest
    GeneralWest Member
    168
    15cms? How much have you lowered your car by? Lol.
    Mine measures:
    35.5 cms on the rear
    35 cms on the front
    I'm running standard shocks and springs, but they are past their best and need replacing (particularly the rears). Hope this helps.
  4. Greig300
    Greig300 Member
    257
    Mine is standard?
  5. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,266
    360
    15cm from centre of wheel to wheel arch...standard??! 17" rims + tyres/2 = ~12.5" ~ 32cm
    32 cm + wheel to arch gap is greater than 32cm..... 15cm!! Nope
    15 inches would be closer
  6. Greig300
    Greig300 Member
    257
    What am i saying its inches... ha cm
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    15 inch is about 38cm
  8. Alex C
    3,266
    360
    yep
  9. hank3944
    hank3944 Member
    146
    I am thinking about 35cms front and rear should be about standard. Some more examples would be really good.
    Thanks guys
  10. jojo
    28,881
    3,532
    hank, what exactly do you think is wrong with your S3 suspension?
  11. hank3944
    hank3944 Member
    146
    I can see the back is higher than the front. just want to know what standard spec should be.....
  12. DenCar
    DenCar Member
    404
    If its any help my wifes is 35cm all round on original suspension.
    DC
  13. hank3944
    hank3944 Member
    146
    Thanks, yes that does help, i thought 35cm was right all the way round.
  14. jojo
    28,881
    3,532
    It would be more helpful if you had an S3, your sig suggests otherwise.
    Hank, S3's have 2 specs of springs, standard and gmbh lowered items. the latter was available as an optional extra in europe, but not UK, and they was standard fit on car with the optional 18" RSTT rims at the time of purchase, that's what I'm lead to believe anyways.
    hope that helps.
  15. DenCar
    DenCar Member
    404
    As i stated........"If its any help"
    DC
  16. mattyboy199
    mattyboy199 Well-Known Member
    1,892
    30
    So did anyone conclude as to weather the suspension will settle ? i have the same problem (rear springs)
  17. s3mad_dude
    s3mad_dude Noggies ruuuule!
    607
    79
    OMG mine looked shocking after my springs were fitted (I did a post somewhere here). They settled down over the course of a few months and I've had them on for 2yrs now. See how you get on but you do need to give them a little while.
  18. mattyboy199
    1,892
    30
    got any pics of how it looked ? the gap, tyre to arch must be 50-70mm
  19. s3mad_dude
    607
    79
    No pics of what it did look like after it was fitted, but I remember getting approx. four fingers in the gap! It's now down to three and I just measured it. It's 35.5cm from the middle of the centre cap to the top of the arch. If yours isn't yet...it will settle over time.
  20. mattyboy199
    1,892
    30
    cool will check the dimension tomorrow although it does sit awfully high. Its a shame one of these top tuning companies havent come out with 10 or 15mm lowering kit in the hope adjustable tie bars arent required. Both my old springs had snapped & the car sat quite nicely without any dodgy camber.
  21. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    Four fingers in the gap, haha, try stretch it to a whole fist :yum:
  22. mattyboy199
    1,892
    30
    I really do hope the springs well lose tension, what i did notice was the springs are under constant compression which is a good thing in this situation.
  23. mattyboy199
    1,892
    30
    checked it out today, i suffer from the 4 finger problem, i really dont get why there isnt a 3rd party that does a 10-15mm lowering kit ! just what it it needs. Shouldnt affect chamber either.
  24. jojo
    28,881
    3,532
    GmbH Factory lowering springs come to mind...
  25. mattyboy199
    1,892
    30
    thats what s3mad_dude had on his & still sat at the same height
  26. s3mad_dude
    607
    79
    I'm happy with mine. Although they have been on two years now! What's the distance from centre cap to arch? Mine is 35.5cm. They will settle down over time, but if you're conscious about it go for some eibachs or H&R...?
    What part numbers did you get fitted for the springs?
