Hardwire your GPS/Speed Detector in
jesters3 Jan 3, 2008
  1. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    I am a novice but it was very straight forward to do and so sorted it out over the Xmas period. I followed Kevin-ST's guide which was very good and helpful:
    http://www.kevin-st.co.uk/tt/road_angel/index.htm
    If you need the 'Snap-Lock' connectors either Maplin or Halfords do them at £1.89.
    I postioned my Snooper at the top of the windscreen and made a bracket that came off the sun visor screw which worked very well. I trailed the power cable up inside the A-pillar trim so that it poked out at the top. This I found was a very neat way of doing it plus the A-Pillar came off easily with a well positoned flathead screwdriver.
    Here's a pic:
    Took about an hour to do it all.
    The only time consuming part was painting the bracket as it took two days to dry!!
