Hard Wiring Sat-Nav... Help
Tallpaul Jan 14, 2007
  1. Tallpaul
    Tallpaul Member
    835
    Well, sort of Sat-Nav. It's actually a trafficmaster YQ2 system but same differance.
    Anyhoo, it comes with a cigarette lighter attachment, i've opened it up and it looks like this:
    It has a simple 0.5amp in-line fuse, on the +ve wire is a resistor. Both the terminals are then connected to something encased in glue:
    Any ideas what this resistor and thingy in glue could be? Some systems have to step down from 12v to 5v... I don't think that's what this is but i want to be sure.
    My plan is to de-solder the red and white wires from the plug, tap the +ve in to an ignition live and fit a new 0.5amp in-line fuse and earth the other wire to the chassis.
    Anyone got any advice or comments?
  2. benw123
    benw123 Moderator
    1,863
    I would have thought your plan will be okay, but it's hard to say what the "resistor" really is. Have you got a multimeter? I'd hook it up inside the car with the attachment and see what current is running through it, just to be sure.
  3. SteveS
    SteveS S6 avant
    691
    when i did my tomtom i bought a spare cigar lighter socket from audi. i connected the red to a ign live and brown to earth. i then hid it behind the dash and plugged the tomtom lead into it. this gives you a hidden power lead without cutting the plug off and spoiling the lead.
  4. 69COU
    69COU Member
    62
    when you wired in where did you decide to mount Tom Tom?
  5. Tallpaul
    Tallpaul Member
    835
    It's ok, the wires are easily removed/re-soldered to the existing plug. I can easily rebuild the cable so no need for a second socket.
