Hard Starting when WARM
connasm Oct 31, 2013
  1. connasm
    connasm New Member
    I have a 2005 A4, 2.0 TDI. Recently bought from a local dealer.
    Car starts perfect from cold, but when the engine is heated up it turns over a few times before firing and when it does fire the bremse light flashes a few times. What could be the problem? Car is still under warranty so I want to get it sorted ASAP. It has been back in the garage and they changed the thermostat sensor but it didn't work!
    Any help would be appreciated.
  2. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,319
    767
    Breather hole in the filler cap blocked?
    Bremse light is a small machine gun. Rough area where you live if you have one fitted :laugh:
    NHN likes this.
  3. connasm
    connasm New Member
    Must take a look at that too, thanks. I've also seen a good few people saying that it could be the temp sensor for the coolant. Garage seem a bit confused or not interested for some reason! :( The Bremse light flashes 3 or 4 times after a hard start why would that be?
  4. NHN
    29,299
    1,702
    Starter motor or coolant sender are common ones to check tbh when engines warm & bad starting.
  5. connasm
    connasm New Member
    Cheers for the advice. Hoping that it's the temp sensor on the coolant. Looks to be the easiest fix but knowing my look will turn out to be more!
  6. pistonripper
    pistonripper Member
    34
    I had the same problem for a while now. Changed coolant and fuel temp sensor no difference. I'm thinking this may be a route to my mpg problem. Starts on first turn when cold. Anybody know any s@it hot techs in the Birmingham area.
  7. connasm
    connasm New Member
    What sort of MPG are you getting at the moment
    If you find the cure will you please let me know, I want to get this fixed before my warranty runs out in a month!
  8. lynallbel
    lynallbel Active Member
    395
    I havent a clue on audis, but on my wifes old mini, there were twos sensors, one for dash gauge, other for ecu.
  9. Big Al
    Big Al Active Member
    487
    66
    Get yourself to Badger 5 in Gloucester for a fix mate. Alternatively Audi themselves are great in Birmingham and Solihull. Forget the local VW 'specialists' as they are all hopeless - as are Midland VW in Cannock.
  10. pistonripper
    pistonripper Member
    34
    im getting 22/24mpg...likewise if you find one let me know
