Hard into gear after brake fluid change
AudiLeon Mar 16, 2010
  1. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,171
    150
    Our lasses car is hard to get into gear after I did the brake fluid change.
    I suspect its down to needing to now bleed the clutch fluid? The res' got abit low at one point, if my brother got bored and had pressed the clutch down. it could have air in?
    This all relies on if the A3 100 tdi Y reg has a fluid clutch?
  2. sportstractor
    sportstractor Chugger
    2,709
    lol you have answered your own question mate. Bleed the clutch, all will be solved
  3. AudiLeon
    2,171
    150
    So they are fluid clutches then? I shall bleeeed it, any ideas as to where it is? I had a look the other day and couldn't see it.
  4. Matt82
    Matt82 Active Member
    2,365
    on top of the gearbox youll see the slve with hyd hose leading to it and bleed nipple
  5. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Unless it has the concentric slave cylinder which I think it might have with that year and being a TDI.
  6. AudiLeon
    2,171
    150
    Easy to bleed though? My old vectra just a bleed screw on top of the box. I'll have to have another ganders when i put my new rear caliper on.
