Handling poor since new alloys fitted
djx11b Feb 14, 2012
  1. djx11b
    djx11b Member
    160
    Got a set of genuine 18" bbs ch alloys with 215 40 18 falken tyres on them recently. since fitting them to my s3 8l the handling has went very poor the car is understeering on most corners even at low speeds. would the alloys cause this with the tyres being stretched or would i need to maybe upgrade my suspension or some bushes to make it handle better ?
    i have 8mm spacers on the back for a better stance and no spacers on the front. i thought it was due to the roads recently but dry today and no grit on roads so should handle normal.
  2. <tuffty/>
    21,356
    3,923
    215/40/18's are a bit narrower than is normally fitted... 225/40/18 as a rule... plus what wheel size/tyre size have you come from? if you are comparing pilot 3's to FK452's for example then its never gonna be the same..
  3. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    Stretch tyre- less tread on road surface...bound to affect the handling dude.
    That's why cars like Porsche, Ferrari and such have wider wheels than the average. More tread on road...better traction
  4. Oranoco
    Oranoco Well-Known Member
    3,957
    404
    Stretched tyres will do you no favours as it reduces teh needed sidewall flex to keep the tread on the road where it's meant to be. As has been said the do seem on the narrow side too. What tyres did you have on there before hand as I'm not a fan of Falken tyres at all and would rate the Kumho KU31 in much higher esteem for a budget tyre
  5. djx11b
    djx11b Member
    160
    thanks for replies guys
    i got the tyres along with the alloys i think they were on awesome al bora before i got them from him. i had standard 17" s3 alloys with goodyear f1's on before i knew they would not be as good but didn't think it would go so poor.
    have just went up to the local garage and checked tyre pressures and they were a bit low so have pumped them all up a bit and has help to a degree.
    i'm looking at getting suspension kit, r32 arb and, s3 dave tie arms so once there fitted should handle better hopefully
    also will go for a wider tyre when they need replaced in the future would 225 be ok if i am going to be lowering the car with the new suspension kit ?
  6. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    Hopefully it will keep the tyre patch in contact with the road, but stretch will always compromise the tyres performance. When you think you've got 4 patches smaller than the average sized mans shoe footprint, every little helps. Weather conditions /cold will make it worse so hopefully as it warms up a bit it may help.
  7. S3Steve
    S3Steve Active Member
    1,621
    19
    You should defo be running 225/40/18 tyres mate, and yes they will be perfectly fine on a lowered S3 its exactly the wheel and tyre combo ive been running for the last seven years mate.
  8. djx11b
    djx11b Member
    160
    could do with larger tyres and getting some upgrades for the car arb, suspension etc
    problem with remap at moment and going to cost a bit to get sorted right so going to have to sell the alloys to fund that gutted :(
  9. S3featesV9
    1,032
    12
    Pm me if you do sell them...priced without tyres. Cheers :))
