Hand brake adjustment
david7m Feb 18, 2014
  1. david7m
    david7m Active Member
    551
    44
    Hi
    Am I right in saying there isn't any ?
    I've fitted new pads but the hand brake still requires 6 clicks. Is this normal, just looks a little high?
    Guess new cables would be the next option which won't be happening.
    Dave
  2. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    Try checking underneath the ashtray in the centre console behind the handbrake. That's where it was on mine.
  3. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Seized rear caliper?
  4. david7m
    551
    44
    Both calipers work well and I will check near the hand brake itself.
    Just out of interest, how would a seized caliper affect the travel?
    Cheers,
    Dave
  5. jojo
    28,942
    3,597
    Rear calipers are self adjusting aren't they? Try yanking it up and down a few times, and it should require less click to operate the handbrake. I stand to be corrected though....
  6. david7m
    551
    44
    Yeah, I've tried that and nothing happened.
    Dave
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    To adjust the hand brake remove the rear ashtray and adjust with a 10mm spanner
    david7m likes this.
  8. david7m
    551
    44
    Win -
    Dave
  9. QuestMS
    QuestMS Member
    67
    Make sure when you fit the callipers back on that there isn't a big gap between the pad & disc. Wind out the piston slightly to make it sit closer to the disc then adjust the 10mm nut under centre console.
    david7m likes this.
  10. david7m
    551
    44
    Yeah, going to revisit the calipers at the weekend to check they evenly wound back in as in my picture above it doesn't look like it's pulling square....
    Dave
