halogen headlight hell help needed
the jammy one Oct 10, 2010
  1. the jammy one
    the jammy one Member
    193
    hi im currently in the process off changing my b6 to a b7 but my headlights are not working properly my old ones where halogen ones and my new ones are also halogen ones i think that they must have changed the wiring round but i cant find a diagram anywhere and currently now cant drive at night due to no lights this is my daily drive and have kids and a misses and we now have no car its beond bearable i found a diagram on audizine but it didnt match must be difrent over there i dont even have a clue how id be able to test the wires to figure what went where please can sumone help it isnt even on my workshop manual
    many thanks jay
  2. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Can you get access to VAG com, as this should find the fault.
  3. paul20v
    paul20v Audi fanatic
    1,113
    You will need a volt meter and figure out what comes live when switched on
    you can look inside the lights to the back of the plugs and work out what goes where
    Vag com aint going to help thou
    why does everyone think these days that if theres a problem it must be sorted with a diagnostic machine .
  4. the jammy one
    193
    i dont have any access no is there no way of testing by hand wire outputs ect but saying that even if there was ho would i know which pin theyed go to on the headlight id off asked the guy on hear who did the conversion on his but he hasnt being on since august see if he had same issue or if his where just plug and play thios isnt good lol i hack the loom up im queit confident but its knowing what needs swaping with what
  5. the jammy one
    193
    so you mean test out put of wires when indicator on then main beem and so on ect so i have them figured out then look inside my lights and trace whice pins lead to which light??
    but how would i figure out positive and negives ?
  6. the jammy one
    193
    or the levleing wires? sorry to be a pain
  7. paul20v
    1,113
    All the wires obviously correspond to actualy wires going to bulbs etc
    so you can visually sort the wiring out by the process of tracing wire from bulbs to pins internally in the lamp
    its a bit of a drag but can be done without a tester .
  8. the jammy one
    193
    you sir are a legend thanks very much for you help its so simple now youve told me but when your turing your hair out thinking wtf you just dont see the ansew and it realy is quite simple lol ill make sure i have afew fuses spare just incase lol thanks again
  9. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    Tip - Brown is ground or earth - that's the easy one!
