Haldex System Not working?? Front wheels spinning???
NDK2013 Feb 27, 2014
  1. NDK2013
    NDK2013 Member
    68
    Hi Guys,
    Only noticed this the other night when I had to drive over some grass and got stuck in my S3!!! Front wheels spinning nothing coming from the rear??? No Spinning, nothing at all from it!?
    Any ideas??? And any ideas in kings lynn area I can take to look at? I hear it could be a fuse but what fuse am I looking at/for???
    Thanks in advance
    Nathan
  2. S3AMK20VT
    S3AMK20VT Member
    170
  3. NDK2013
    NDK2013 Member
    68
  4. NDK2013
    NDK2013 Member
    68
    Any ideas??? Never happened to any 1 else?
  5. kanecullen89
    kanecullen89 Active Member
    569
    160
    43
    I think lots of people have had these issues before with the haldex system but there's many things that can affect it.
    The haldex system is electronically controlled so it could be something as simple as the fuse blown or could be the pump or controller.
    The easiest bet would be to see if there is any vcds users in your area to scan and see what faults are picked up.
    I can't help much because I've never had a haldex car (I've got an A4 quattro) so don't have first hand experience but there is a lot of knowledge on here and I know these problems are quite common so well worth a search
    NDK2013 likes this.
  6. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,759
    Gfermer likes this.
  7. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
    Pre charge pump is the likely cause - common issue.
  8. RobinA3
    1,827
    47
    If you can get someone with vagcom they can test the pump by sending a signal to it to make it prime - if it's working then you will hear it.
  9. veeeight
    6,849
    4,759
    Only if his car has a Gen 4 Haldex, will there be a pre-charge pump :)
    edit: Gen 2 still has a coupling pump though, but this only normally operates above 400rpm. It could be this that has failed.
  10. NDK2013
    NDK2013 Member
    68
  11. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Should try switching OFF ESP in such conditions.
  12. NDK2013
    NDK2013 Member
    68
    I did fella, Just front wheels spinning! may as well been in my old VXR!
    kanecullen89 likes this.
  13. NDK2013
    NDK2013 Member
    68
    Hi thanks for this....
    Audi changed it so i'm hoping so!!
    Whats the clutch Pack??
    Nathan
  14. kanecullen89
    569
    160
    43
    The haldex system has a clutch pack in it. The pressurised oil pushes the clutch pack together to transfer the drive from the driveshaft to the rear wheels
  15. MrLapou
    1,233
    121
  16. NDK2013
    NDK2013 Member
    68
    I cant remember to be fair?? But even with that on the fron wheels jump if i boot it from a junction and also they did not even try to move at the rear when stuck?? surley it would at least try and move the car???
  17. ron burgandy
    ron burgandy Active Member
    295
    It's your haldex pump, it needs replacing
  18. NDK2013
    NDK2013 Member
    68
    What's the likely cost. Any ideas?
  19. Keane
    Keane Active Member
    470
    66
    Many people have problems when changing the heldex oil ! I've got mine booked in with Audi but getting put off lol. Can I ask how much it cost you ? Cheers
  20. NDK2013
    NDK2013 Member
    68
    Really can't remember to be honest. I think it was around £125 ish I think
  21. NDK2013
    NDK2013 Member
    68
    Any one know part number for pump so I can look to get this ordered???
