Haldex problem
edward_harris Apr 1, 2008
  1. edward_harris
    edward_harris s3 gone now a shiney red evo 6
    1,061
    Hey guys
    changed my haldex controller the weekend for a standard one, ever since then its only been front wheel drive. A little oil came out but not alot really. So i put the uprated one back on, and still its front wheel drive. Checked fuse number 31 looks fine. What else can it be? Also how do you check the haldex oil level and change it?
  2. 1animal1
    9,978
    eeerrrrrmmmmmm...... couldnt you ask a simple question
  3. edward_harris
    1,061
    Meaning its only front wheel drive 4wd dosent engage. i just get loads of wheel spin
  4. jojo
    28,935
    3,587
    I recommend you do a vagcom check on your car ed, sounds like a loose connection or something, if it was working before.
  5. edward_harris
    1,061
    anyone with VAGCOM in the area?!
  6. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    I have it (A4 Twyford/Wargrave) and Nick Evelry has it (Jct 11)
  7. Longman
    Longman vassdignostics.co.uk
    I agree, VAG-COM will show if there are any communication problems between the ECU and the Haldex controller. Thats what I would expect to see.
    Have you got an ABS or Traction Control light on the dash?
    Remind me is fuse 31 one of the ones above the battery. If not I would check them too?
  8. edward_harris
    1,061
    no its the one one in the car. could it be one of those fuses then?! Are you about the weekend at all dave could you have a check over for me?! If it was low on oill would that cause it not to work?
  9. edward_harris
    1,061
    oh and no lights on the dash have come up!
  10. Dave_Bayern
    1,913
    I'm about the weekend Ed, if you make your way over to mine I'll check it for you no problem. Send me a PM.
    Dave
  11. jojo
    28,935
    3,587
    I recommened you take it for a quick spin also and give us some feedback Dave. ;)
  12. Longman
    Yeah, let us know how you get on.
    One of the large fuses under the bonnet over the battery is for ABS/TC communication. I looked at Ballcrushers car on here with a communication prob to the Haldex and ABS and it was a connection to that fuse that was shot.
    Well worth a check.
    V/C will show this anyway.
  13. edward_harris
    1,061
    Checked the fuses on top of the battery they were all ok! Guess we will have to see what VAG COM says!
  14. edward_harris
    1,061
    well dave check the vag com and after he cleared everything, no other faults came up. Still only front wheels drive tho. So i changed the haldex again for the standard one and changed the oil still not working! If its to low on oil would stop it working? Any other ideas?
  15. Dave_Bayern
    1,913
    Only thing that came up on yours was brake light switch - intermittent.
    However, it also came up under the AWD control module, is that something that affects the haldex operation?
  16. edward_harris
    1,061
    what is the AWD module?!
  17. Dave B
    Dave B REALITY?.... WHERE AM I AGAIN?.... WHO AM I AGAIN?
    175
    Could it be that the AWD/Haldes systems can't see the brake applications to read how to apply 4wd ratio's?
    Dave
  18. simch
    simch Active Member
    2,028
    Well if the hadbrake is aplied, the handbrake has a switch which disables the haldex.
    Maybe its the same with the foot brake.....?
  19. Longman
    Edward: AWD moduile is what controls the 4wd system (All wheel drive)
    I would definitely start with the brake light switch if it has come up on both controllers. It would make sense for it to diable the haldex if there was a problem like that.
    Its under the dash behind the pedal.
  20. edward_harris
    1,061
    but the brake lights are working fine! They were playing up before, so i adjusted it and works fine now!
  21. edward_harris
    1,061
    Then i would always have problems!!
  22. alijames
    alijames Active Member
    1,024
    Are we getting BORED again?
    Cheers,
  23. scott_johnson
    scott_johnson Audiless
    876
    Ed, how did you remove the haldex controller. is it easy???
  24. edward_harris
    1,061
    it is if you have a ramp and a ratchet with a pivot on the end other wise it can be tricky getting to the top bolt! I used a small allen key the first time! Why do you need to take yours off?!
  25. scott_johnson
    876
    got a fault thats always there from vagcom. haldex memory controll error. Was goin to wack it off and see if there was anything up with it!!
  26. edward_harris
    1,061
    it would prob be a electrical prob with it, and i guess the only way to sort it would be a new controller or get someone to repair yours!
