Haldex problem is now abs problem
nokia_aid Jan 31, 2012
  1. nokia_aid
    nokia_aid Member
    47
    ok i had this error coming up
    Address 22: AWD Labels: None
    Shop #: WSC 00000 000 00000
    VCID: 55ABA648FC1A496
    4 Faults Found:
    16347 - Control Module - EEPROM Error
    014 - Defective
    02248 - Valve for Controlling Clutch Operating Angle (N373)
    014 - Defective
    014 - Defective
    014 - Defective
    so i changed my haldex unit and the oil and filter(which was horiffic black oil coming out)
    now the code above is gone but i have a new code
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 C
    Component: HALDEX 4Motion 0108
    Coding: 0000001
    VCID: 2D5B2EA8B40A1E1
    1 Fault Found:
    01316 - ABS Control Module
    008 - Implausible Signal
    anyone have any idea,i know that Part No: 1K0 907 554 C is the new haldex i just fitted
    and this one has not gone away
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No: 1K0 907 379 E
    Component: ESP ALLRAD MK60 0104
    Coding: 0023170
    Shop #: WSC 06435 000 00000
    VCID: 346D3BCC57204F9
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
    013 - Check DTC Memory
  2. nokia_aid
    nokia_aid Member
    47
    ok the haldex i removed had 1K0907554A and the one i fitted has 1K0907554C on it,could this be an issue maby C is slightly older and not compatable with A
  3. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    Is one module Gen 2, and the other Gen 4?????
    Not sure on the error codes, maybe NHN Nige might know.
    Sorry cant be more help.
  4. nokia_aid
    nokia_aid Member
    47
    my car is a 2005 and the replacement modual came off a 2005 so should both be the same gen
  5. shariain
    shariain Well-Known Member
    1,182
    190
    Had a look on etka for 1k0907554a this part has been replaced with 1k0525130a which was then dropped and replaced with 1k0525130f which has now been replaced with 1k0525130L on the 01/06/2007.
    When you look at the additional info for 1k0525130L there are 2 types G0L 6 speed manual and G0R 6 speed auto.
  6. shariain
    1,182
    190
    When you put in 1k0907554C part number in etka it tells you it was replaced and then points to 1k0525130L and this control unit changed on the MY08 haldex to gen 4 control units which are in use with all new haldex units.
