Haldex oil change cockup!
vfr800 May 17, 2012
  1. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    773
    57
    Hi
    I put the car on ramps and changed the haldex filter and oil, the job was pretty easy, didn't lose much oil when I put the new plug and washer on.
    Torqued it up to 15nm as per the manual.
    Cleaned the area afterwards to look for leaks and noticed this :sob: :banghead: :shrug: :wtf:
    New washer time?
    Has this happened to anyone before?
    Should I drop the oil and put in a known amount again seeing as I'll lose a bit more if I change the washer?
    Help?
  2. <tuffty/>
    21,242
    3,879
    I know there is supposed to be a torque applied to most things but common sense should prevail here realistically... last haldex plug that got torqued up I know of resulted in stripped threads...
    The torque arguably applies when its all new and shiny but once over a certain age and of course after its been off a few times then tbh torquing the plug up is less appealing... you get a better feel doing it by hand tbh...
    Doesn't look like its leaking yet
  3. vfr800
    773
    57
    Thanks. Now I know! :)
    I went for a bit of a drive on a short loop and it's weeping slightly.
    It's a shame the GSF I'm in walking distance of doesn't sell the sump plug or washer :(
    Liam
  4. adamss24
    adamss24 Well-Known Member
    4,584
    406
    Why not get a suitable penny copper washer and change it ? Halfords do a wide selection and i'm sure you an get a decent selection from a plumbase or good plumber supplier ! As per above post, i trust my hand more than i trust a calibrated torque wrench !
