Haldex not working?
s3 Hoggy Nov 11, 2010
  1. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    155
    Everything with my car has been working sweet as a nut until yesterday. Basicly I put my foot down and get a lot of wheelspin with no signs of the haldex helping out?
    It's always been serviced on time (the haldex) with the last oil and filter change 4,000 miles ago. I don't experience any other symptoms like others have with thee point turns ect, also my car has only done 52,000 miles.
    Anybody have Ideas as to why this might be happening?
    Thanks for reading,
    Matt
  2. alijames
    alijames Active Member
    1,024
    Matt, The obvious one is the fuse. Failing that, best way forward would be a Vag-com start to the investigation.
    I've got an eBay serial one which works fine on 409.1 on my laptop. Sadly I'm away from tonight, otherwise could have brought it into Oxford this morning...
    Cheers,
  3. finesse
    finesse Active Member
    2,805
    best to scan
  4. s3 Hoggy
    1,716
    155
    Ah well mate no worries, I'll hopefully be getting it plugged in tonite if the garage round the corner will fit me in,
  5. s3 Hoggy
    1,716
    155
    Just phoned the garage and they can't fit me in for two weeks! Even for a diagnostics check! Think I'm going to buy an EBay lead and see if any thing shows up?
  6. finesse
    2,805
    eBay cable will do
  7. colicabcadam
    colicabcadam Guest
    could also be the hand brake switch, if this is fooked, it'll stop the haldex working
  8. s3 Hoggy
    1,716
    155
    Would this not cause the handbrake light to be on all the time mate?
  9. colicabcadam
    colicabcadam Guest
    in THEORY yes
  10. alijames
    1,024
    Matt. if you are getting an eBay lead, I would advise getting a serial one, rather than a USB one. I tried 3 USB ones and none of them worked. 1st Serial one worked perfectly and still does..
    Cheers,
  11. Nilz
    11,274
    846
    Dude, is there nobody else nearby that can do a scan for you??
  12. Welly
    Welly VX220 SC Driver :)
    10,696
    126
    Dude, check the fuse as mentioned as first port of call. It's fuse 31. Top fuse in the middle column. Will be orange IIRC.
    Next, have a look at the plug on the diff. I've seen 2 separate S3s where this has become corroded inside and needed repair.
    If you are not getting any Haldex, then expect an error code along these lines:
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    1 Fault Found:
    01324 - Control Module for All Wheel Drive (J492)
    49-00 - No Communications
  13. s3 Hoggy
    1,716
    155
    Thanks for your help guys,
    Checked the fuse, looked fine but I still replaced it. That didn't sort it worth a try.
    Next I will be checking the plug on the diff as Welly said (will have t wait till Saturday now as no light)
    I will be ordering a lead tonight
    Thanks for everyones help so far,
    Matt
  14. colicabcadam
    colicabcadam Guest
    get the wheels off the ground, see if they all spin when you put it in gear, if thye do, i'd say it's a sensor problem (ie 5% of power is going to the wheels, so the heldex isnt broke)
  15. pj123
    pj123 Member
    307
    12
    Isn't there an earth strap that corrodes back there? Vaguely remember reading about it but may have not been onto the haldex...
  16. s3 Hoggy
    1,716
    155
    Where abouts is this mate? I had a quick look in the dark with a torch but its bloody cold and windy so I've come back inside! also where abouts is the earth strap?
  17. The Doctor
    The Doctor Well-Known Member
    1,396
    189
    Keep us posted with this one Hoggy, hope you get it sorted.
  18. s3 Hoggy
    1,716
    155
    Will do pal
  19. SamiG
    SamiG On Boost, ish.
    233
    Earth strap on the rear diff.
  20. mhr1972
    mhr1972 Member
    37
    I had this last year and it was down to my earthing strap from body to rear diff/haldex.
  21. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    yes worth a check....
  22. s3 Hoggy
    1,716
    155
    Cheers guys I'll have a look hopefully tonite if It's still light, can any body confirm which side the earth strap is on?
  23. s3 Hoggy
    1,716
    155
    I have found this, could it be the Earth strap? It's bolted from the drive shaft to the underside of the spare wheel well. As you can see it's pretty fecked! Snapped in half
  24. alijames
    1,024
    Yup. That'd do it...
    Cheers,
  25. s3 Hoggy
    1,716
    155
    Right I fixed the strap, I'll be taking her for a test drive in the morning, Fingers crossed it's sorted!
  26. Duktor
    Duktor Member
    282
  27. s3 Hoggy
    1,716
    155
    bad news the strap doesnt seem to have fixed the problem,
    I have found a fault code though, does anybody know what this might be? my repair on the strap wasnt fantastic as I was rushing so might have another look at that in the morning?
    VCDS-Lite Version: Release 1.0
    Saturday, 13 November 2010, 17:09:28:0
    Control Module Part Number: 02D 900 554 C
    Component and/or Version: HALDEX LSC ECC 0009
    Software Coding:
    Work Shop Code:
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    Any help would be great,
    Cheers Matt
  28. pj123
    pj123 Member
    307
    12
    I thought I'd check the earth strap today while I was changing my oils. I have a pre facelift model 1999 and it does not have an earth strap at all...
  29. JS1500
    JS1500 Howdy
    1,166
    10
    New strap is only summin like £13, IIRC.
  30. SamiG
    233
    Definitely that earth. Get a new one from Audi.
  31. s3 Hoggy
    1,716
    155
    Does anyone know if the earth souls be bolted to the chasis and the spare wheel well? As I've only bolted it back to the wheel well
  32. dantheman1986
    dantheman1986 Member
    262
    did you find the problem in the end s3?
  33. s3 Hoggy
    1,716
    155
    Not yet mate but everything seems to be pointing towards the haldex controller, havnt got s lot of time to get it sorted at the moment, as soon as anything changes I'll update this thread
  34. s3 Hoggy
    1,716
    155
    WooooooooooooooHooooooooooooo! Fitted a second hand haldex controller this morning and now I have my 4wd back! Big thankyou to Rob (aka Cecilthesausage) for the part
  35. karls s3
    karls s3 Member
    234
    Hi mate was this easy to fit..
  36. s3 Hoggy
    1,716
    155
    It wasn't that hard as such, I done it on ramps as you are best off with as much room as possible. It's just a case of removing the cover plate that protects the haldex plug, then unplug it there and also unplug the haldex at the controller itself, two Allen bolts hold the controller on undo these and your away! You loose a spoon full of oil. Then just repeat in reverse to fit the new one, holding the gasket in place is the biggest pain in the arse! I would reccomend getting the top screw in first a couple of turns then the bottom ensuring you still have the gasket it the right place. Tighten it all up and reconnect the plugs and your there.
    So yeah it's not a difficult job just fiddly and I kept getting **** in my eyes!
  37. karls s3
    karls s3 Member
    234
    Cool cheers mate as I will need to get hold of one soon and fit it..
  38. cecilthesausage
    cecilthesausage ...It's Never Finished...
    933
    112
    No bother mate glad to help nothing worse than a sick S3:crying:
  39. s3ben19
    s3ben19 New Member
    how much and where do you find these contol units
  40. cecilthesausage
    933
    112
    I sold mine to Hoggy for £100 pound which I think is about the going rate.... Dont know how often they come up though bud:think:
