Haldex not working, lots of wheel spin.
MattS5 Jun 22, 2014
  1. MattS5
    MattS5 Active Member
    619
    60
    Noticed the car is struggling to get the power down this last week.
    Initially thoughtit might be tyres but it's actually the rear wheels are not being driven .
    A quick Google search reveals a possible pre pump issue might be to blame.
    No lights are on the dash so it's off to the garage this week for an investigation.
    Has anybody had similar issues with an 8P?
  2. Alex_Wil
    Alex_Wil S3 - DSG - Black Edition - TTE Hybrid Turbo Regional Rep
    1,212
    839
    Hi Matt .
    I just had a problem with haldex clutch pump and had to get that replaced . are your front wheels spinning and traction light flashing ?
    RedDejavu likes this.
  3. MattS5
    619
    60
    Hi Alex.
    Yep, if I plant my foot, the wheels will spin and flash the ESP light.
    Was yours a warranty job? I'm out warranty by 4 months.
  4. Alex_Wil
    1,212
    839
    Could be exactly same as mine .. With regards to warranty it's a tricky one .. my car was still under warranty and I've had a remap and they said no but after I had it done I found out it should of been under warranty because it was an electrical fault which wouldn't of been caused by the power from the map! If it's mechanical they could argue it's down to the power in the car if you've had a remap ?
    Has your car had anything done to it ?
    MattS5 likes this.
  5. MattS5
    619
    60
    Had a remap.
    My thinking was around a goodwill gesture, even 50% would be a result.
    Like you're saying, a remap could put more stress I the drivetrain, but a pump would be electrical, so can't reallysee why they would fight too much over it .
    But, I'm 4 months out of warranty so could well end up paying.
    Any idea what the cost/time was for yours?
    Cheers.
  6. Alex_Wil
    1,212
    839
    It's definitely worth asking , Depends on the dealer aswell I suppose !
    Audi charged around 500 Inc vat fitted and I got mine done for around 300 Inc vat fitted from AMD for a whole pump replacement ... not sure if it's most audi garages but some just used a repair kit to fix it but could be better to change whole pump ?
    MattS5 likes this.
  7. MattS5
    619
    60
    £300 doesn't seem so bad.
    I should imagine the part itself is quite an easy swap, but the pump is the biggest expense.
    Many thanks for your replies, that's at least given me some idea of what it might be.
    Cheers.
  8. Alex_Wil
    1,212
    839
    No problem . try and see if audi will do it under good will and if not and you can't get to some were like AMD ,audi do price match work on audi genuine parts so you should be able to get a cheaper job from them anyway !
    Alex
    MattS5 likes this.
  9. MattS5
    619
    60
    Checked with AMD to see if they used genuine parts or if they had a supplier of refurbished units.
    They confirmed they use new genuine parts, so I called Audi today.
    The part itself is £200, so I'm guessing my local independent will be able to fit in an hour plus the cost of some Haldex oil, for about a £100
    If I had any idea how easy the oil is, I'd tackle it myself as my Dad has a pit in his garage which makes this stuff pretty simple.
    My only concern is that I might need special tools or process for the oil removal and top up.
    For the sake of the hassle, I'll get it fitted by my independent.
    Audi "might" give me some goodwill on the part, but if it's double the labour charge, I'll end up paying more.
  10. s3_trev
    s3_trev Northern Ireland Gold Supporter Audi S3 Team Brill Red
    1,866
    646
    How many miles are on it?
  11. MattS5
    619
    60
    It's done 56k in 3 and half years.
  12. s3_trev
    1,866
    646
    Did it get its haldex service at 38k?
  13. MattS5
    619
    60
    Yep, sure did, bang on the mileage. (DSG was done at the same time).
    It feels more likely to be pump (electrical) related other than oil/mechanical as it literally stopped working with no other noise etc.
    s3_trev likes this.
  14. Statler
    Statler Old enough to know better Team Daytona Team V6 Gold Supporter A7 Owner Group
    543
    413
    I read somewhere else here that the guy pulled the haldex fuse to make the car run on the front wheels.
    Assume you've checked the fuses?
    Alex_Wil likes this.
  15. MattS5
    619
    60
    When I looked at the fuses and relative roles performed, the Haldex was run from the same fuse as the DSG gearbox.
    The DSG box is running fine, so I never even bothered pulling the fuse, if you see what I mean?
  16. jaygemson
    jaygemson Active Member
    154
    91
    Are there any fault codes stored?
    Just thinking out loud, my TT reverted to front-wheel drive only and that turned out to be a corroded electrical connector to the Haldex unit right at the back of the car. Audi wanted to replace the whole Haldex unit before I found the problem and fixed it myself for pennies.
    ron burgandy likes this.
  17. MattS5
    619
    60
    It's in the garage on Friday, I have no way of checking fault codes unfortunately.
    I'm sceptical that its the connector, I read its a possibility with the 8L version of these cars, but they would be getting older so was kinda thinking that at just over 3 years, the connector would still be good (but also cause the issue to be more intermittent if a dodgy connection maybe?)
    I'll mention it to the garage when I drop it off on Friday, that's for sure, but might pop over to my parents and check the connection over my dads garage pit in the meantime if I get chance.
  18. s3_trev
    1,866
    646
    God that's worrying then. Keep us updated, id be very interested to find out whats causing your problem.
  19. MattS5
    619
    60
    Audi UK had 38 pumps in stock.
    That tells me it's a relatively common issue.
  20. MattS5
    619
    60
    Yep, had it confirmed today as the pre pump for the haldex. It's gone open circuit.
    New one ordered and being fitted next week, which will include a haldex oil change too whilst it's being fitted.
  21. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    funny how many pumps have gone within last few months just around this forum.
  22. s3_trev
    1,866
    646
    Flip. Thanks for keeping us up to date. Will keep this in mind if I ever have issues. How much was the part?
  23. Alex_Wil
    1,212
    839
    What year is your car matt ? - do think it could be affecting the newer 8p?
  24. RedDejavu
    1,806
    337
    61 plate buddy have bought it dec 11
  25. Alex_Wil
    1,212
    839
    Seems more common for 08- cars? That's three people in a 2 months its happened!
  26. MattS5
    619
    60
    2011 61 Plate.
    It seems more common on cars around 2010 - 2011 by the looks of the replies on here.
    I'll be glad to get it fixed, the car is a bit of a handful with just the front wheels being driven, you really notice it when pressing on, especially overtaking.
    The part is £200 for whoever was asking. Fitting is relatively straight forward but makes sense to change the oil at the same time which pushes the price up to over £300 .
    Not that bad really.
    S. and Alex_Wil like this.
  27. RedDejavu
    1,806
    337
    Yet dearer than swapping the exhaust and taking back to audi on the warranty isnt it:D. Thats the only reason I swapped my milltek however this pushed me to buy a new exhaust now as I always wanted the powervalve system! :(. So it's ended up as a very expensie repair!
  28. MattS5
    619
    60
    Prefect example of man maths in operation there! Very much the way I'd go about things normally....car's, men and money, what a financially ruinous combination.
    (Not men in a relationship type of way, just to clarify!)
  29. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,761
    ^ we don't judge on here! what you do in the evenings and weekends is up to you :p
    RS3dan and S. like this.
  30. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,042
    559
    i guess you ended up with a better sistem so it's still a win!
    i'm tired of milltek on highways but can't afford new sistem now :D
  31. RedDejavu
    1,806
    337
    is your resonated or no? If not maybe a resonator could help out with this? I dont really know what to expect from this powervalve system but people say its good. Took me few good months to decide on buying though...
  32. westtra
    westtra New Member
    20
    What's the best way to diagnose the fault? As my S3 has been doing it since purchase just under a month ago. Put it down the the winter tyres that previous owner had on the car but still doing it with eagle f1 asymmetric tyres on. Will take it back to the dealer for a check aswell sometime next week.
  33. MattS5
    619
    60
    Pretty much wheelspins whenever floored out of a junction or in 2nd and 3rd gear plus torque steer. All the time the esp light flashes whilst the wheels spin.
  34. westtra
    westtra New Member
    20
    That's what I am getting. Wheel spin in 2nd under hard acceleration on a nice dry road.
  35. westtra
    westtra New Member
    20
    Little update car was plugged into audi diagnostic comp today and its thrown up a fault with the haldex controller so booked in for repair.
  36. Alex_Wil
    1,212
    839
    Might be silly question but ill ask anyway. Is the controller different from pump ?
  37. westtra
    westtra New Member
    20
    I am assuming so going by a little bit of googling. The haldex controller is the electronic gubbings on the side http://img-2013.tapatalk.com/d/13/02/18/uqugu7ad.jpg that you change out if you upgrade the controller.
    Cars in for 2 days to diagnose fully, order parts and repair.
  38. westtra
    westtra New Member
    20
    Car fixed today. New haldex pump and car now accelerates without traction control cutting in.
  39. 83jmh83
    83jmh83 New Member
    21
    Wish I hadn't read this, mine appears to have this issue when pulling away from lights. Glad I got it from dealer now not private. Looks like that warranty is going to come in useful!
  40. turbonutz
    turbonutz Active Member
    421
    61
    hi i got an 08 prefacelift s3 and that seems to be wheelspinning now!? but not all the time? done a vcds and no haldex faults came up? anyone any idea haha? also anyone got part number for haldex pre pump just to look it up?
