haldex issues on dyno?? :(
Rob_B Apr 10, 2011
  1. Rob_B
    Rob_B Member
    192
    Hi chaps,
    I was at a dyno day today, my s3 was attemping a run however the haldex was playing havoc with the dyno and the car just couldnt run up...i was just wondering if anyone else had similar experiances and what is the way to solve it?
    can you simply full the haldex fuse out to leave it front wheel drive?? can you use a vagcom to switch the car into perminent 4wd??
    any help appreciated :)
    regards
    rob
  2. <tuffty/>
    21,363
    3,928
    Pull the fuse mate... do it all the time....
  3. Rob_B
    Rob_B Member
    192
    simple as that...doh! lol..cheers mate
    will go back to the dyno and do that :)
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Number 31 for reference.
  5. Rob_B
    Rob_B Member
    192
    nice one welly, is it found in the fuse panel on the side of the dash or is it under the bonnet somewhere
  6. Welly
    10,696
    129
    In the side of the dash mate, top of the middle column on the bank of 3 columns.
    Just look at the fuse map on the cover.
  7. R1KVX
    R1KVX Member
    108
    will it do any damage taking the fuse out? sorry if its a stupid question
  8. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    It can do but we all do it before Dyno's just remember to put it back after
  9. badger5
    9,507
    2,003
    for short power runs, its ok.
    sustained running however I would'nt advise - it will get hot with the prop moving and the clutch pack not.
    Usual dyno runs for power check are short and not sustained like when mapping cars -
  10. Speedy Steve
    Speedy Steve Active Member
    1,258
    and diont forget a warning light will come on after you have put it back in and driven off for a little bit but will clear itself
  11. R1KVX
    R1KVX Member
    108
    oh right thanks guys, I put mine on the dyno on the weekend with the fuse in it was ok, but the graph had a horrible power line instead of a nice smooth curve it was all over the place up + down would this be to do with the fuse being in? just trying to get to the bottom of this problem
  12. badger5
    9,507
    2,003
    you ran it with fuse in in front wheel drive mode?
  13. R1KVX
    R1KVX Member
    108
    the esp was turned off, is that what you mean?
  14. jojo
    28,908
    3,564
    Legend if he did! lol
  15. badger5
    9,507
    2,003
    nope.. not what I meant.
    esp not haldex isolation.. handbrake on would(should) prevent rears working but its not the same as disabling the thing by removing fuse.
    Did the car go onto a 2wd or 4wd dyno?
    only front wheels turned yea?
  16. Brendan12
    Brendan12 Member
    141
    Get it on a 4wd dyno. I went on a Dyno Dynamics 4wd rolling road the other day and it ran in 4wd with no problems.
  17. cecilthesausage
    cecilthesausage ...It's Never Finished...
    933
    112
    These are my graphs Rob with Haldex issues [​IMG].... Undynoable next time round... For whatever reason which I couldn't even begin to explain lol
