Hello.
About 3 months ago i bought a Skoda Octavia 2006 1.9tdi 4x4 estate.
Last week the ESP Light came on, it reset and went away with an ignition change, it has done this a few times since although it will always go away and stay off with ignition cycle.
I took it round a mates earlier to have a little play with VAGCOM, and quickly came across a fault i was not expecting to see.
02248 - Valve for controlling clutch operating angle (N373) 014 - defective - intermittant.
Fast forward a week and i took the car to work, removed the haldex controller, checked and cleaned all electric connections with electrical cleaner, cleaned out the Solenoid Valve N373 (seems in good condition) nothing obvious to report.
Put it back in and i appear to have made the situation a whole lot worse !
Perminant 4wd failure, ESP light on dash, faults are now as follows.
By what i have read i believe there is propably water ingress on the side of the circuit board that i did not access as it is sealed (there was some slightly pushed up bits of sealant which i oversealed).
What im trying to find out, is do others here agree with my diagnosis, and what is the most cost effective repair ?
Second hand is a possibility, but a gamble, refurb would be possible but the car is in daily use so could not send it off to be done as i would have nothing to cover the diff with !
Could be possible to find the damaged bit of the board and solder it up, dunno with out looking.
Any help or ideas would be appreciated.
Thanks very much, Dan.
