Haldex Diff Whine?
ollyhawkeye Jul 7, 2009
  1. ollyhawkeye
    ollyhawkeye Member
    105
    Ladies and Gents,
    I have started to notice a slight whine from what I can only think is the Haldex unit. I drive an MY07 S3 which is totally standard.
    Its not a loud whine but its noticeable when coasting, it's not the wheel bearings as it only does it when coasting and the noise doesn't change when going round corners etc.
    I have recently had the oil changed on the haldex so its fully up to date with servicing etc. I will probably take it to the dealers and see what they think about warranty.
    Has anyone got any experience with this or had a warranty fix etc before I get it checked out??
    Olly
  2. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    if its under warrenty it shouldnt be a problem mate just take it to them and dont leeve till they agree somethings wrong with it
  3. panamadi
    panamadi Strider
    96
    I've found exactly the same thing with my s3-thought it was normal??
  4. yahyar
    yahyar Member
    are you talking about a loud ZZZZing when lifting off the throttle or puttin the clutch in?
    also, the prefacelift haldex used to give me a heavy thump from the back when changing gears under load
    thankfully both these issues are gone on my MY09
  5. Flibble
    Flibble Active Member Team Estoril
    544
    142
    43
    My 05 plate haldex doesn't thump under load...
  6. Dandle
    Dandle Member
    852
    No mine didnt, sounds like it may have had a mount loose or knackered.
  7. tobycruse
    tobycruse Member
    289
    Its your haldex mate. Mine did exactly the same thing, got it replaced under warranty. Same path you should take!
  8. SiT
    SiT Member
    99
    See this thread Olly. http://www.audi-sport.net/vb/showthread.php?t=70200
    It definitely could be your Diff; I’ve an 07 S3 with similar problems.
    Thanks to Toby mine is at Audi today getting it replaced under warranty, fingers crossed that will it as it has been a long drawn out process, it just takes some persistence. I get it back on Monday so I’ll report back then.
    Sie
  9. RGS3
    RGS3 Member
    125
    Hmmm, how do we define the whine ? I've noticed something similar on my 07 S3 recently and been trying to think how I'd explain it. In my case seems to be when I touch the accelerator (so related to drivetrain? rather than when coasting) - the whine is coming from the rear, not easily noticed unless your expecting it.
  10. ollyhawkeye
    ollyhawkeye Member
    105
    Thanks for all the replies!! I am defo going to take it in to the dealers and get it sorted then.
    Will keep everyone posted though, not sure I'll be heading there way for while though, work is manic - not that I am complaining....
    To describe the noise, it is when you are on a smooth road and you back off the gas a little. There is a slight whine from the haldex when it meets resistance. That's the best way I can describe it really. Requires a smooth road and the radio off but once you hear it it's then the only thing you hear if you know what I mean.
    Thanks again
    Olly
  11. SiT
    SiT Member
    99
    Olly - My diff has been replaced and can report the whinnning noises have vanished. I pointed out to my dealership other members from this forum with same issues and it has eventually come to the right conclusion.
    Get Audi to check your diff.
    Ta
    Sie
  12. ollyhawkeye
    ollyhawkeye Member
    105
    Thanks Sie,
    I think I will be down there Wednesday so will get their warranty guy to have a look see then.
    Olly
  13. S3OPES
    S3OPES New Member
    19
    Just had mine replaced after the same problem, my prop shaft was knacked aswell. My noise got louder with someone in the back aswell.
    Matt
  14. ollyhawkeye
    ollyhawkeye Member
    105
    Finally got the car into the dealers after they recommended I changed all 4 tyres, so I put some Eagle F1 Asyms on and the whine was still there.
    It went into the dealers yesterday and apparently it was missing a counter balance weight off the prop shaft - something I didn't know they had.
    So I will be picking it up later, hopefully minus whine!
  15. GConn
    GConn Member
    236
    Mine makes a slight whine (for a few seconds) every half a minute. The dealer confirmed it is the Haldex, but won't change it under warranty yet. The whine is not detectable when the car is not stationary or when the radio is on, it's not a loud sound at all.
  16. ollyhawkeye
    ollyhawkeye Member
    105
    Yeh I think mine was a combination of tyres which needed changing and the prop shaft missing this weight. Hopefully I'll be all sorted after this. As much as I love taking it in for warranty work this is the 3rd time in 6 months....
  17. Jamiekip
    Jamiekip Member
    717
    Mine started whinning, dealer did the haldex oil change early on it and that cured it.
    Maybe invite them to try this, as I think the 40,00 mile limit to change this is optimistic (mine started whinning just after 30k miles).
    J
  18. ollyhawkeye
    ollyhawkeye Member
    105
    Yeh, I had the oil changed at 40k. I do plenty of miles. Should have bought a diesel really.
    46k and counting......
  19. dgannon
    dgannon Dolphin Grey 2007 S3
    99
    I've had this, but am not convinced it was the rear diff since a new one hasn't resolved the issue so thinking it could be the front diff/gearbox...
    Audi tell me it's just a characteristic, similar to the much louder whining noise you get when driving in 1st gear...
  20. ollyhawkeye
    ollyhawkeye Member
    105
    Yeh I must admit I have just driven it home and it actually sounds exactly the same. It had about £200 worth of parts swapped out. For those who are interested parts below.
    A1K0 521 307 A - Coupling - £189.37
    AN 103 291 02 - Bolt - £1.17
    A1K0 521 137 - Bushing - £19.40
    I think I am going to monitor the situation for a week and then take it back in. Maybe it's just me.
    They have washed it too, even when I specifically asked it not to be! It winds me up. Got to get the clay out this weekend to rectify their calamitous efforts at cleaning a car.
  21. edition
    edition Active Member
    1,426
    Ah is the 1st gear whine normal then?
