Joshstan
Hi all as above I am getting the code for haldex clutch mechanical malfunction I have today changed the haldex oil and filter and also the precharge pump
But when I got to draining the oil there was absolutely none in there I think I got 1 drop when removing the drain plug and nothing came out when I removed the pump either
I can't do output tests on Vcds lite but the pump does not run when the engine is running. Is this normal? I bench tested the new pump and all was well same with the one I removed
Basically this is a long way of asking am I going to need a new diff?
