Hairline cracks & buckles in Alloys
37 Nov 11, 2013
  1. 37
    37 Member
    129
    Hi,
    Is there a way to find hairline cracks or buckles in the Alloys? I've got some off eBay (With tyres) and now a bit skeptical if they are not good etc or if there is a problem! THe chap said that they have come off his car and it wasn't involved in any accident either...
  2. nluk100
    nluk100 Active Member
    987
    181
    43
    Take them to any decent tyre / balancing garage and ask them to check them (usually free)
  3. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    If cracked, the tyre will loose pressure.
    Buckles are normally more pronounced on the inside of the rim... i.e. portion furthest from the spokes.
    Tyre place will spin then slowly on the machine to see if they spin true.
  4. Artimus
    Artimus Shortback
    2,016
    485
    Why so skeptical? is there any obvious damage?
  5. Bedders
    Bedders Member
    104
    I had a 17" Audi alloy crack just after i'd had some tyres fitted. Thought they'd not sealed the bead correctly or not used a new valve. As another said previously a sign of cracked alloys is losing pressure. Mine went down to 10 psi after about 10 days from the high pressure required in this size. On the second return they put the alloy in a bath filled with water & it bubbled like crazy where it had cracked. Mine had cracked on the inside next to the tyre going around into the inside of the alloy for about an inch & a half.
    Just for info mine was a 2008 tdi sportback sport 170 bmn. Wheel was identified on the inside with Audi symbol, ronal brand made in Czech republic. New price at dealers £550 each.....gulp.
  6. 37
    37 Member
    129
    Tyres have been with me for 4 days and they don't seem to have lost pressure. Need to check it soon if I need to return.
    No Damage at all, or so it seems. Seller was great too. Just me being silly I guess : P
    That's probably one of the reason I was skeptical but they do seem good, Czech made too. These ones actually.
    On a different note, could someone post a link for the centre caps?? Can I fit the ones from my 16"?
