Haglos' VAG-COM Scan Results
Caesium Feb 22, 2009
  1. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Wednesday,18,February,2009,20:23:38:41394
    VCDS Version: Release 805.1
    Data version: 20081017
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    Address 01: Engine Labels: None
    Part No: 8L0 906 018 N
    Component: 1.8L R4/5VT 0002
    Coding: 05710
    Shop #: WSC 00736
    3 Faults Found:
    16795 - Secondary Air Injection System: Incorrect Flow Detected
    P0411 - 35-00 - -
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    18057 - Powertrain Data Bus: Missing Message from ABS Controller
    P1649 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V003
    Coding: 18448
    Shop #: WSC 06435
    3 Faults Found:
    00778 - Steering Angle Sensor (G85)
    62-00 - No or Incorrect Adjustment
    27-10 - Implausible Signal - Intermittent
    37-10 - Faulty - Intermittent
    Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
    Part No: 8L0 820 043 D
    Component: A3 KLIMAVOLLAUTOMAT_D75
    Coding: 03141
    Shop #: WSC 06313
    5 Faults Found:
    00787 - Temperature Sensor in Fresh Air intake duct (G89)
    30-10 - Open or Short to Plus - Intermittent
    00779 - Outside Air Temp Sensor (G17)
    00797 - Sunlight Photo Sensor (G107)
    30-00 - Open or Short to Plus
    01297 - Sensor for Vent Temperature; Footwell (G192)
    01206 - Signal for Duration of Ignition Off Time
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 G
    Component: Airbag Front+Seite 2008
    Coding: 01104
    Shop #: WSC 06435
    No fault code found.
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 BX
    Component: AB-KOMBIINSTR. VDO D09
    Coding: 00442
    Shop #: WSC 00736
    Component: AUZ7Z0X1315528
    ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1315528
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    1 Fault Found:
    00526 - Brake Light Switch-F
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 P
    Component: CV-Pump, Alarm, RC D13
    Coding: 13166
    Shop #: WSC 00736
    11 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01365 - Lock/Unlock Switch; Interior
    29-00 - Short to Ground
    00991 - Interior Lights
    28-00 - Short to Plus
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    01134 - Alarm Horn (H12)
    76-00 - Terminal 30 missing
    77-00 - Internal Supply Voltage
    49-00 - No Communications
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00002
    Shop #: WSC 06435
    End ---------------------------------------------------------------------
  2. <tuffty/>
    21,784
    4,169
    Well, look on the 'bright' side, the headlights are ok :)
    ..but seriously... do you know when this lot was last cleared? maybe that some of the faults have been fixed and DTCs not been cleared over time?
    Whats the cars history?
  3. themanthatcan
    themanthatcan Member VCDS Map User
    661
    I'm thinking the same as tufty..some of those may be really old codes. You're best off clearing them and then rescanning it a week later to see which ones resurface.
  4. Caesium
    4,879
    Yup I know all that, this was the before scan.
  5. Haglos
    Haglos jabba mapped
    247
    thanks for reply guys and yes i will agree as the engine in my car was taken out and rebuilt for a price of 3grand and the guy who took the engine out was a vw and audi specialist and his code reader tool was **** but im going to see chris again and go from there
