Had the cambelt and waterpump changed for the first time at 97,000 miles...
ptr Jan 3, 2011
  1. ptr
    ptr Member
    128
    Previous owner never had it done so as soon as I had the funds got both changed, this is what is left of the factory pump, about a quarter of the impeller :ohmy:
    It still ran fine though, no overheating issues in summer and temp always sat at 90 or below. Replaced with a metal impeller water pump so shouldn't have any issues in the future.
  2. shanejess
    shanejess Guest
    its nice feeling afterwards piece of mind. i had mine done at blackburn Audi, 622 pounds, timing belt water pump, major servive, new wipers front and back, oil and filter haldex service also not a bad price i thought.
  3. hades-
    9,481
    646
    very lucky
  4. dany2k
    dany2k Member
    318
    lovely pic, should be a sticky for the dangers of not having your water pump changed!
  5. finesse
    finesse Active Member
    2,805
    lucky
  6. ptr
    ptr Member
    128
    Just amazed that it ran fine like that, no overheating issues at all. Although I suppose it was only a matter of time before the last bit broke away and the temps went through the roof!
    Cheers, took quite a few pics to make sure I did the damage justice :happy:
  7. rich4130
    rich4130 Member
    Mine was like this when I pulled it out the remaining bit just disintergrated, I would change your thermostat as mine got wedged open with plastic!
  8. ptr
    ptr Member
    128
    Just after I had the cambelt done I had a wee crash and needed a new radiator, ever since the temp takes longer to reach 90 and sometimes just sits at 80, not sure if it's the new waterpump or rad thats made the change but do you think it could be the thermostat?
  9. hades-
    9,481
    646
    it could be the CTS
  10. scoobyra
    scoobyra It's not f@cking ORANGE!!!!!
    798
    CTS???
  11. ptr
    ptr Member
    128
    Coolant Temp Sensor? :think:
    Either way a new one is only a tenner from GSF so well worth replacing just incase.
  12. fingermouse
    fingermouse thats me
    3,991
    111
    When I did my cam belt and pump I think I actually broke the pump removing it, its quite tight and if you don`t extract it squarely then Im sure it just breaks.
  13. wibble111
    wibble111 needs to scratch the itch
    841
    My money's on the stat, mine was exactly the same, changed the stat now sits at 90 after 10 minutes and doesnt move at all. IIRC a tell tale of the CTS is a difference between the dash temp display and actual temp display shown on the heater controls and or fluctuating temp on the dash gauge.
  14. ptr
    ptr Member
    128
    Cheers, just googled how to do that climate control trick and will try it next time I drive it.
    Also noticed yesterday the dreaded mayonnaise under the oil filler cap, praying it's just condensation and not the head gasket going. :crying:
  15. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Sounds like the thermostat to me....
    That's not typical symptoms of a CTS problem. Thermostat will generally cause temp to hang lower than 90 degrees. Does it get up to temp when left to sit?
    That's the acid test of this, if you can start it on the drive and leave it, and the temp climbs to operating temp as normal, then your stat is staying open for too long...
