H7 dipped beam/side light leds
scottie123 Jul 3, 2009
  1. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Ok, I have had the bulbs and resistors here for a while but due to work commitments , I havent had the time to fit them.
    Well i am now on holiday, so it is time.
    Trial fitted one side tonight with now resistors, so they only stay on for a few seconds, but long enough for a picture and idea of what they look like.
    sorry for the **** pics.....its dark and i am no photograper! :)
    comments please, and if positive, i may fit them all properly tomorrow!
    obviously, the leds are on the left :whistle2:
  2. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    What bulbs are they? Tonight i just fitted some Philip's blue vision H7 and side lights..
    :thumbsup:
  3. scottie123
    1,972
    Cant remember the brand of them but they are led's :)
    meant to be 6000k h7's on the dipped.
    I think i need some differant side bulbs though as they dont quite match the h7 bulb colour.
  4. A1DEYB
    1,682
    43
    I was looking at these but decided against it http://www.powerbulbs.com/product_detail.asp?prod=154
    I reckon i should of got those now, they'd be a similar color to yours wouldn't they?
    In fact thinking about it, i could just swap my blue visions to the main beam and whack some of these in.. :rolleyes:
  5. scottie123
    1,972
    yes you could. Or even get 2 sets and put the old ones in your fogs. I think they are h7 also :)
    Scrap that, they are h11 by the looks of it for the fogs........:whistle2:
  6. tdisportuk
    tdisportuk Member
    460
    the h7's are led's? could i have the link please? and also where do you mount the resistor?!
    did you change the side lights dipped and main beam to led's?
    thanks
  7. alfiejts
    alfiejts Member
    352
    You can get H7 LED bulbs here - but I wouldn't have thought that LEDs were bright enough to use for headlights yet...
    I know the new R10 has LED headlights, but can't help thinking that the aftermarket led bulbs won't quite be up to that level of brightness...
    I think they're more suitable for turning your existing foglights into "daytime running lights", by swapping the halogen bulbs for LEDs....
    Here are the links:
    http://www.virtualvillage.co.uk/2-x-18-led-smd-h7-white-12v-fog-light-bulb/sku002510-351
    They do an H11 bulb too for those of you that have H11 foglights instead of the more usual H7 fog lights...
    http://www.virtualvillage.co.uk/2-x...ight-bulbs-hid-leds-car-vehicle/sku002510-299
  8. tdisportuk
    tdisportuk Member
    460
    oh ok, so you would reccomend using LED h7 bulbs for main and dipped beam?
    how would i know which bulb my fogs take? is it a question of opening them then checking?
    thanks
  9. alfiejts
    alfiejts Member
    352
    I can't say for sure, but my guess is not.
    The headlights are designed to take the light from one precice focussed point (the filament of the ordinary bulb) and to reflect that into a beam of light, using the reflectors.
    The LEDs won't be putting out in the right place to create the right shaped beam of light.
    I'm more interested in getting the brightest headlights for night driving than the colour myself - but realise that others have different priorities...
    My best experience so far is Phillips X-Treme Vision bulbs. They're a very white light and in Autoexpress tests, came out the best of all the conventional halogen headlight bulbs.
    Anything with a blue tint will look nice, but the tint will always reduce the light output.
    Its only a 5 minute job to remove your fog lights to see what type of bulb they use.
    I know mine are H7 but I do hear others say theirs are H11....
  10. tdisportuk
    tdisportuk Member
    460
    yeah im after the HID xeon look, so its best i should buy Phillips X-Treme Vision bulbs have used osram in the past, wasn't really happy with the outcome
  11. tdisportuk
    tdisportuk Member
    460
  12. redbutcher
    redbutcher Member
    649
    Hmm, maybe it's the pic, but they do look a bit too blue for my liking.
  13. tdisportuk
    tdisportuk Member
    460
    @ scottie123 mate in the first picture what bulbs are you using on the right hand side? halogen ones obv but what brand? there like clear clear white, sort or something im after!
  14. scottie123
    1,972
    I think that the photos really dont show what they really looklike .
    The ones on the right are standards, and are actually quite a horrible yellow in real life.
    Still deciding now what to do.
    I am just not convinced by the leds out put. In real life , the colour of them is pretty much what i wanted, but I just dont know if they are going to be bright enough for driving.........
    I just dont want to start splicing resistors into the wiring looms just to take them all out again.
    I might just use led sidelights, and get some uprated H7,s
    So maybe if someone wants some h7 leds and resistors, they could be getting sold.
    Still sitting on the fence though.......:think:
  15. alfiejts
    alfiejts Member
    352
    The Philips X-Treme vision are a really strong white.
    They're not the "bluey-white" (if that's what you really want), but nor are they yellow either.
    I've not heard anything about the Ring bulbs, but in Autoexpress tests, the Ring offerings always came out worse than the Osram or Phillips equivalents...
    The Phillips X-Treme +80% bulbs came out ahead of the Osram +90s
    I've got X-Treme +80s in my dipped beam, I've put my old Osram Silverstars in my main beam and I've got H4 X-Treme bulbs in both my Yaris SRs....
    I think the Phillips are4 the brightest and truest-white halogen bulbs you can get at the moment...
  16. scottie123
    1,972
    Think i may get some of the philips extreme then.
    Cheers for the heads up alfiejts!!
  17. tdisportuk
    tdisportuk Member
    460
  18. scottie123
    1,972
    dont know mate. The onl,y reason i can think of is that perhaps of the colours and intensity , they are dazzling. I know i have been past a few cars which i presume have these on and they can be quite bright.
    However, saying that, i'm not sure what the differance will be between them and the white extremes, as these surely are also very bright and possible to dazzle, as the are 80% brighter.
    Maybe someone knows the exact reasons why?
  19. Lee_R
    Lee_R Active Member
    2,499
    12
    I have the philips xtreme in mine, I can confirm they are very white, not a hint of blue to be honest.
  20. scottie123
    1,972
    Did you find a good improvement at night with them?
  21. alfiejts
    alfiejts Member
    352
    Being obsessive about headlight brightness, I've tried nealry every bulb that's come out over the past few years - especially those that did OK in the Autoexpress bulb tests.
    I've used Phillips Vision Plus, Osram Silverstars, Halfords Megabright, GE +60s plus others I can't remember.
    I haven't tried the really expensive PIAA bulbs, but of all the road-legal 55w bulbs I've used, the X-Treme vision are noticeably brighter than any of them....
