H&R's or Eibach Sportlines
rOb_A May 17, 2012
  1. rOb_A
    rOb_A Active Member
    1,488
    After a too long a think, I'm definately going to drop my car, so which is better H&R's or Speedlines. I'm looking for 40-50mm drop, so both do that job but which are best for look and ride?? also who the best to buy from?
    :footy:
  2. Ads
    Ads License to drive
    8,230
    607
    I would recommend the Eibach Sportlines, but I am a bit biased.
    Reasons for me choosing them over H&Rs:
    1) Eibach drop 50mm at the front and 40mm at the rear, giving a more even arch gap. H&R drop 50mm all round which gives reverse rake (bigger arch gap at the front than the rear).
    2) Eibach are a softer/less firm ride than H&R.
    3) If you want to upgrade your shocks at a later day then you can match them with Bilstein B8 shocks, which effectively means you've got the well matched Bilstein B12 kit.
    If you plan on fitting the springs yourself then you're probably best buying online from DPM or GNJ on here.
    But if you are going to pay to have them fitted then you should see if you have an AMD near you and they will supply/fit/align the Eibachs for £300 in total, which is a bargain seeing as the springs alone are about £160.
  3. DPM
    DPM Site Sponsor Site Sponsor
    4,969
    196
    I'd agree, I prefer the slight nose down look from the Sportlines.
    Damian @ DPM Performance
  4. Kallend
    Kallend New Member
    Damian how come they don't do the sportlines for quattro's?
  5. rOb_A
    rOb_A Active Member
    1,488
    Whats you best price fella to a ASN member? for the sportlines for a 2012 fwd 2.0tdi BE
  6. bluequattro
    bluequattro Member
    411
    Im using h&r on my quattro, the combo of ride comfort and handling
    is excellent, ive also used eibachs which were about the same imo
    Cal
    rOb_A likes this.
  7. Rom
    Rom Member VCDS Map User
    443
    Ive decided to go for Sportlines myself. Not got them yet though.
    Done a lot of reading on here about them etc.
    Have a search, loads of info.
  8. rOb_A
    rOb_A Active Member
    1,488
    cheers Ads, think i'm going to take your advise and go for Eibach's. will have a look around to see where you buy. hope damian @ dpm will be able to sort me out.
  9. DPM
    4,969
    196
    Sportlines are the lower range kits from Eibach so offering that amount of drop on a Quattro wouldn't get TUV approval.
  10. DPM
    4,969
    196
    Replied to your PM.
  11. Ads
    8,230
    607
    Do the H&R -25mm springs for the S3 have TUV approval?? The S3 is Quattro and these H&Rs give a 25mm drop below S3 height which is effectively 60mm below standard A3 height.
  12. rOb_A
    rOb_A Active Member
    1,488
    Damian, which are the better springs for the 2.0tdi fwd? if the sportlines are the lower range kit?
  13. DPM
    4,969
    196
    They do yes.
  14. DPM
    4,969
    196
    Between which springs?
  15. rOb_A
    rOb_A Active Member
    1,488
    within the Eibach range? and between h&R and eibach?
    how to i go about placing an order? plus whats the delivery time?
    cheers in advance
  16. Farhan
    Farhan Active Member
    1,234
    57
    Damians service is fantastic, not sure if you saw my thread recently but the pictures will give you a really good idea of the ride height.
    I ordered my springs from Damian and they were sent exactly to my requirements but he held them instock pretty much ready for next day delivery.
  17. rOb_A
    rOb_A Active Member
    1,488
    cheers farhan :thumbsup: i'll have a look for the your thread lad but if you can post a side pic that would be great. did you fit the springs yourself?
  18. Farhan
    1,234
    57
    Most of the pics are in the thread but that was literally 2 days after fitting. Iv noticed now throughout the week the front has settled more so if possible ill take more snaps.
    I fitted them at my mechanics with aid but the fronts were a complete and utter nightmare! Rears on the lift took maybe 10 mins....The fronts took nearly 2 hours as the drive shaft bolts were SOLID, we could not remove them and even broke a breaker bar. (Impact Gun) would not remove them.
    My cars an 08 so i was surprised to see how solid they were, They didnt look like they were rusty but just really tight guessing they have not been opened since it was built at the factory.
    I would suggest getting the fronts fitted at a garage with access to a lift as it made it alot easier when having the shock pulled out form the hub assembly.
  19. 210_MIH
    210_MIH Drive it like u stole it
    108
    Farhan, is yours a sportback? can you put some pics up??
  20. rOb_A
    rOb_A Active Member
    1,488
    cheers lad! has the front dropped slightly further then? yep a good side pic of the stance would be great fella.
    also i've had a 3 door about 3 1/2 years ago but can't remember if the interior light is 1 module or 2 like my sportback. just costs together for a possible new 3 door.
  21. Farhan
    1,234
    57
    Mines a three door
    Photo below i had 2 people in the car
    No Passengers
    And Before pics
  22. rOb_A
    rOb_A Active Member
    1,488
    definitely looks better fella. i'm thinking of going over to 2.0tdi 140 as opposed to my current 1.8tfsi which i like. have you had a go of the tdi 140?
  23. Farhan
    1,234
    57
    I have sat in one and been for a drive, nice engine as well. I prefer petrols and on book the tfsi units quicker but the 140 TDI is alot more economical. Since remapping mine i do struggle to see over 35mpg now.
  24. rOb_A
    rOb_A Active Member
    1,488
    i've driven both too. as said i like the petrol over the diesel but don't think there is must between them unless you really push it. my sb is standard and i still only get around 35ish mpg, therefore tdi is looking favourable if i change.
  25. Kallend
    Kallend New Member
    Damian, Thanks for the info, will be in touch shortly regarding and order!
  26. DPM
    4,969
    196
    If you want the lower option go for the Sportline springs and if you want something a little more subtle go for the Pro springs. Out of the H&R 50mm and Eibach Sportline 50mm/40mm I'd personally go for the Eibach kit.
    You can order online at DPM Performance Online Store or over the phone on 01207 561606 and delivery is usually the next working day depending on which kit you went for.
  27. rOb_A
    rOb_A Active Member
    1,488
    springs have been ordered and should arrive tomorrow for fitting at the weekend all being good.
    how long do they normally take to settle? and against the s line springs, those who have fitted them are you pleased with the drop and ride?
    :racer:
  28. rOb_A
    rOb_A Active Member
    1,488
    anyone
  29. Farhan
    1,234
    57
    Hey fella, I think mine are still settling and its been two weeks. I noticed the rears sat correctly straight away as they are seperate to the shock so generally the weight just sits on them so they stay fixed.
    The front needs to settle a bit as its a bit reverse rakey at the moment. Id say maybe 1000 miles before you notice they have settled quite a fair bit.
    I am very happy with them, Comfortable over all speed bumps in london with no scraping on the front bumper etc yet. The ride is also miles better than the S Line set up. I found the sline crashy considering the car was very high before. I would say ride comfort is alot more smoother over nice smooth roads on bad pot holes its about the same.
    The springs really do help with cornering and handling though before the car felt to soft on corners i wouldnt get any feedback and sometimes it would slip out under spirited driving.
    After lowering you get alot more feedback so you know if the cars going to let slip etc.
  30. rOb_A
    rOb_A Active Member
    1,488
    cheers lad, really appreciate your comments. any daylight pics similar to your before shot?
  31. Farhan
    1,234
    57
    no probs glad i could help, not yet but going to give the car a clean tomorrow ill take some daylight snaps for you.
  32. rOb_A
    rOb_A Active Member
    1,488
    get them posted lad :thumbsup: when you've taken so that i can.
    new bits and bobs arrived today, plus a lot ££££ spend. going to be a busy sunday!!!
  33. Rom
    443
    Got my Sportlines fitted, pita job. Stupid Nyloc and Allen Key heads. Why Audi cant use flats on the back of droplinks i dont know.
    Rears are lower than fronts atm. So either they need to settle, or just because rears are tucked into arch, or thats just how they are.
    Befores
    Afters
  34. rOb_A
    rOb_A Active Member
    1,488
    you happy with the drop? i'm coming swapping from s line springs so unsure if I'll much difference
  35. Rom
    443
    Yeah prety much. Rears maybe a bit low, but only in comparison to the fronts. So if the fronts drop a bit more, or if rear spacers fix it, im a happy camper.
    How much lower are Slines than Sports ?
  36. rOb_A
    rOb_A Active Member
    1,488
    i thinks its 10mm
  37. Rom
    443
    Well thats still 25 mm front i think ? 10-15mm rear?
    Do they not all end up the same height anyway? I mean 50 mm on a base model, 35mm on a sport, and 25mm on a sline, should all end up -50 from base?
