H&R Trak+ 10mm (20mm Per Axle) Hubcentric Wheel Spacers & Bolts PCD 5/112
Scott Dec 14, 2009
  1. Scott
    Scott Well-Known Member
    1,306
    126
    Hi Damian
    Does this set include 4 or 5 bolts?
    Scott
  2. DPM
    DPM Site Sponsor Site Sponsor
    4,938
    184
    Hi Scott,
    It includes 10 bolts.
    Damian @ DPM Performance
  3. Scott
    1,306
    126
    Hi Damian
    That's what I meant ;)
    Will be ordering in a sec.
    Scott
  4. DPM
    4,938
    184
    Thanks Scott!
  5. Scott
    1,306
    126
    They've arrived, thanks Damian A+
  6. DPM
    4,938
    184
    No problem Scott, thanks again for the order.
  7. Scott
    1,306
    126
    Hi Damian
    Cheers for the advice earlier on the phone. I used a long screwdriver to get it off, gave the hub a clean, repeated this a few times and finally went on OK.
    Had the fronts fitted aswell when I took the car in to have the coilovers adjusted, since they had the wheel off anyway. It's all good.
    Do you know which locking wheel nuts are suitable with the bolts you provided, as I'm under the impression if the locking nut is longer/shorter or different weight, it can send the balancing out and cause vibrations. Not sure in the truth in this?
    Scott
  8. DPM
    4,938
    184
    No problem, glad you got them on.
    Yeah that's right. On the front you have 14x1.5x37mm and on the rear you have 14x1.5x40mm. You should be able to get them direct from McGard.
