scott_johnson
Hey all! Just thought id share the new spring pics, also gave it a clay / limeprime and purple haze wax (dodo juice) and the results were awesome!!
Car looks
1animal1 Jeff acrylic is great done mine yesterday... love it. Amazing results that last. Used it afew times normally do two coats of it.
LTN - its spot on mate, car looks very well!! TBH i thought it was expensive but having put a coat on every weekend for the last 2 months...can really see the difference...plus the car stays cleaner for longer!! (seems that way)
Tim
Cheers for the comments guys!! I can honestly say im over the moon with the springs! Even with the standard dampers the ride has improved 100% ... no too stiff not too soft and body role has improved loads!! (not that bouncy either considering the dampers) As for the lowering, it says 25mm but id of said more than that. I wanted the fk springs which lowered more at the rear as most s3's look slightly higher at the back but the H&R'S did the job perfectly!!! I would recomend to any one. I got mine for £198 delivered from dpm!!!! Give Damien a shout!!
Looks awesome mate!..ive just had mine lowered with h & r springs.it says 35mm drop,but it hasnt droped that much!.ill give it a few weeks and see.but the ride is still very good.not an s3 tho!...
