H&R spacers
Smoothie Nov 22, 2010
  1. Smoothie
    Smoothie Active Member
    1,431
    Ok running 50mm springs and 18" wheels
    They are in need of spacers, anyone running them on here with similar setup? Not sure what sizes to go for
  2. sub39h
    sub39h Active Member
    2,502
    i thought the general consensus was 10mm all around. that's what i'm gonna go for
  3. A3_Kenny
    A3_Kenny New Member
    9
    I was going to order 10mm for the front and 12mm for the rear but wasn't sure if it would rub or not.
    Are you ordering longer locking wheel bolts as well? Anyone got pics with there spacers fitted?
  4. Smoothie
    1,431
    The ones I've looked at come with longer wheel bolts yea
    I really don't know what size would be best, all I know is I want no rubbing lol a wider rear might be a better look than 10mm all round. Hopefully someone will be along with some expertise
  5. A3_Kenny
    A3_Kenny New Member
    9
  6. Smoothie
    1,431
    hmmm what's the thinking on rears only??
  7. A3_Kenny
    A3_Kenny New Member
    9
    Could always try the 10mm's on the back first and if it doesnt give you the look you're after then swap them to the front and get 12mm's. Thats what im doing anyway, just trying to source longer locking wheel bolts first before i go ahead and order.
  8. Scott
    Scott Well-Known Member
    1,306
    126
    I have 12mm on rear and it rubs sometimes but I think that's the alignment as I had full geo setup and it started, also, it hasn't done it for a while, but very bumpy roads it does it a lot. But if you're looking for a setup that 100% won't rub, then 10mm.
  9. Smoothie
    1,431
    Roughly how low are you on the coil-overs mate?
  10. DPM
    DPM Site Sponsor Site Sponsor
    5,040
    212
    10mm front and 12mm rear is always a popular choice.
    Damian @ DPM Performance
  11. Smoothie
    1,431
    any prices friend?
  12. Richy_C
    Richy_C Active Member
    706
    159
    43
    I was of the understanding that 10mm front and 12mm rear, apparently the feedback is that the rears only rub if you leave that screw in place, if you look at your rear arch you will know the one instantly. removing that = no rubbing so im told.
    Also after pricing a good few up Damian was very competitive as you get the bolts also. its just the offsets that worried me if you start reading into it too much.
  13. Smoothie
    1,431
    Worried you mate? How so?
  14. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,473
    610
    You ordering some smoothster? Who from?
  15. N8
    17,163
    718
    Avoid H&Rs at AT ALL cost, I have 2 sets snap on me, and know of 2 other forum members that have had this happen as well, the collars are FAR too weak.
  16. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,294
    372
    ok, avoid HnR, what would you recommend then?
  17. N8
    17,163
    718
    Ive not used any others, might give forge ago on my new rims.
  18. Alex C
    3,294
    372
    mmm, HnRs were the first port of call really and the obvious choice.... shame
  19. jungleman
    jungleman Well-Known Member
    2,035
    42
    What happens if they snap? The collars I mean
  20. Alex C
    3,294
    372
    if the collars snap then your spacers won't be hub centric and the load will be transfered to the wheel bolts rather than the hub, not sure how likely the bolts are to snap though. However, without hubcentric spacers you wheel won't be centered properly on the hub and you will get wheel vibrations around 70mph
  21. N8
    17,163
    718
    The collar seperated from the spacer and got stuck inside the back of the wheel, driving home from preston to manchester with wobbly bolts isn't something I'm going to experience any time soon. So from my PERSONAL EXPERIENCE. So when your H&R wheel spacers arrive the postman might as well say..
  22. PH1L
    PH1L Gievf Buckets
    3,851
    40
    h n r or forge are the best spacers hubcentric as always and dont use them as they werent intended, better yet plan your wheels and offsets and you can end up with a really nice setup, speak to the above on this as he is deffinately the wheel guru of the site
  23. N8
    17,163
    718
    Apparently this is me?
    Its all hype.
  24. V16
    V16 Member
    214
    :laugh:
  25. NHN
    29,510
    1,764
    lmfao N8 isnt a wheel guru, he's a sheep overlord
  26. N8
    17,163
    718
    Bristol is not in WALES
    :laugh::laugh::laugh:
  27. Smoothie
    1,431
    Well I was planning on it lol but not looking good from the above
    Waiting on a price from Kirkpatrick tyres before I buy online, would rather give it to ban RMS'r
  28. jungleman
    2,035
    42
    can try these guys, i was gonna order them from there before i picked some up second hand
  29. NHN
    29,510
    1,764
    Close enough me old fruit
  30. N8
    17,163
    718
    NO NO NO :laugh:
  31. Smoothie
    1,431
    What guys?lol did you go for H&R? With all these warnings not sure if H&R is the right choice?
  32. jungleman
    2,035
    42
    ah forgot to include the link!
    Tarox Extras - Discount Prices at Motorsport World
    i didnt know about the problems when i got them, but this is the first ive heard of it, a friend had forge ones go on his BMW M Coupe just luck i guess, but as teh H&R's are TUV approved they should in theory be pretty reliable
  33. Smoothie
    1,431
    Eibach anyone?
  34. DPM
    5,040
    212
    If you don't want to go for H&R both Eibach and Forge are also very good brands.
    Give me a shout if you need any prices.
  35. N8
    17,163
    718
    Thanks day.
  36. Smoothie
    1,431
    Well has no one had any of H&R's replaced? Especially if it's so common?
  37. N8
    17,163
    718
    Yes I did. I'll be trying forge if I need 10mm on my new rims
  38. Smoothie
    1,431
    Crazy stuff from such a reputable manufacturer, might be worth a bit more research
  39. N8
    17,163
    718
    Jus try Forge lad :ninja:
  40. Smoothie
    1,431
    Yea il price the forge, anybody on here got them?
