H&R Cup Lowering Springs & Shocks kit???
Ads Jul 28, 2011
  1. Ads
    Ads License to drive
    8,230
    610
  2. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    never seen this fitted.. i reckon its the perfect alternative to coilovers.. Springs are good but i can definately feel the fact the springs aren't matched to the dampers. My springs look good, but when going over bad road surface they feel less balanced than stock. Im told this doesnt happen when you have a matched damper. So with this kit you shouldn't have that problem... and a lot cheaper than H&R Coilovers! my 2p Ad
  3. Ads
    8,230
    610
    What you've said about your handling is my worry about just changing my springs only. And it would be worse with my Sport dampers.
    Think I might go for this kit.
  4. DaveyB
    DaveyB No misfires.
    269
    I am interested in the same kit for the S3. I would probably be inclined to go down the 'spring' route but the ride can be a bit crashy as it is where I am with the standard suspension already. There was clearly only so long I could hold off the temptation to mod...
  5. Richy_C
    Richy_C Active Member
    706
    159
    43
    That's what I have on mine, really nice and yes it's firmer over speed bumps but I like the ride more on the road. I've had springs before on a cooper S and I was too bouncy. Rebound is good on the H&R's
  6. Richy_C
    706
    159
    43
  7. Ads
    8,230
    610
    How much did you pay in total for the kit and fitting if you don't mind me asking??
  8. Richy_C
    706
    159
    43
    I got the kit from Damien, same link as you have up top, was the best price, fitting I can't remember, was just over £100 I think say £200 to be safe.
    If I had one comment it would be to get the spacers while your at it, looks much nicer.
  9. Ads
    8,230
    610
    I should be getting a lower offset set of wheels soon so will see how they look without first.
  10. moag
    moag she's no d-turbo
    821
    35
    for an extra £50 or so you could have a set of kw coilovers. Far better option IMO, you'll be able toget the ride height just as you want it
  11. Ads
    8,230
    610
    These -------> KW Variant 1 Basic Coilover Suspension Kit A3 8P / A3 8P Sportback 1.4T Si, 1.8T FSi, 1.9TDi, 2.0T FSi, 2.0TDi FWD 05/03> - £604.00 : The premiere online mail order VAG suspension and performance specialists. We offer a wide range of all the best br
    Do you know anybody who has used these???
    I'm assuming the H&R kit is going to give a better quailty ride?
    To be honest, i'm not really bothered about changing heights, -50mm H&R gives pretty much exactly the height I want.
