H&R anti roll bars....advice needed please
Rabbit222 Nov 6, 2008
  1. Rabbit222
    Rabbit222 Active Member
    708
    125
    43
    Hi guys, is there anyone here that has installed H&R ARBS? I need some assistance with regards to the setup. I currently have it set to soft up front and stiff at the rear. Car feels great in the twisties but I'm interested in what she would feel like if the front was stiff and the rear stiff too? Would this stuff up the ride in anyway or would this be better for Quattro? My local suspension guru says he installed it as per how he installed it on GTIs but those cars are FWD and not AWD :confused:
  2. boggysv
    boggysv Member
    573
    Do you really need the stiffer rear?
    Can understand the requirement for it on FWD Gtis that they want the rear to be more tailhappy, but we have haldex/quattro. I'd like the rear to have more grip when the haldex wants to transfer power backwards.
    Have a read at this, just to make your decision harder.
    http://www.golfmkv.com/forums/showthread.php?t=62927
  3. Rabbit222
    708
    125
    43
    With the current setup, the car feels very planted at the rear whereas the front feels abit loose? I'd like this to be setup properly for quattro and am not exactly sure what would be the better option.
  4. Rabbit222
    708
    125
    43
    Thanks for the link, makes for very interesting reading.
  5. jonnyc
    jonnyc Member
    858
    Just give it a try, remember you can combing the holes on the bars to create in between settings, such as (hole 1 front left, hole 2 front right) which would be an in between setting compared to (hole 1 hole 1) or (hole 2 hole 2)
    If that makes sense..
    Anyways it only takes a minute to change so I would suggest just having a play around with it..
    With our cars, IMO they should be set up like a FWD chassis, the S3 understeers like a pig..
    You need a good base set up to work from though, the bars should only be used for tweeking rather than changing the balance of the car..
    What geometry set up are you running on your car at the moment?
  6. N8
    17,163
    720
    I've got H&R ARBs Sean...
  7. Astakos
    Astakos Member
    30
    and your setup is?
  8. N8
    17,163
    720
    H&R ARBs is my set up
    you cheeky sod
  9. Rabbit222
    708
    125
    43
    Geometry setup:blush: Math wasn't my fav subject at all dude:) What exactly do you mean Jonny? I did some hooning this weekend and I honestly can't believe that I waited this long to fit ARBs to my car. She feels so stable in bends that before produced plenty of roll...now she feels like a go kart!
  10. Astakos
    Astakos Member
    30
    Obviously I was referring to how you have adjusted them, front-rear, as I have ordered them as well and I could use some piece of advise here!
    And for the shake of it I did not mean to be offensive in anyway...you took it all wrong mate! :unsure:
  11. jonnyc
    jonnyc Member
    858
    Yeah they are mega!! Cant believe I sold mine really, going to buy another set shortly though :)
    Geometry, so Toes, camber, static rake etc.. Not too tricky, if you set it up like you would a FWD car, so..
    Plenty of front camber 3-4 degrees, need adjustable top mounts for this really as the standard bottom arms dont allow for any adjustment, KW have just released a kit. Stand the rear end up so maybes only 1 degrees negative
    As for the toes I would go with 1mm toe out each side at the front, and .5mm toe in at the rear
    Then as much positive static rake as your comfortable with, I run about 5mm
    Then as much caster as what you can achieve on the standard front suspension set up
    I would personally run the ARB's full stiff all round, its still fairly compliant :)
    Good luck mate
    Jonny
