H&R 35mm & 19"
rabs Apr 3, 2008
  1. rabs
    rabs Revo
    101
    Just thought i would show you a few pictures of my car.
    I was searching for ages to find how my car would look with different setups so hopefully this may help someone else decide.
    I have 35mm drop H&R springs with 8.5j * 19" ET48 rims with 235-35-19 Tyres
    18" rims with H&R
  2. AudiLad
    AudiLad Member
    145
    that looks sexy mate:rock:
  3. L60N
    L60N Guest
    And a behind view of the wheels please (rear arch)
  4. rabs
    rabs Revo
    101
    Will do
  5. dipstic
    dipstic Member
    384
    Looks good,any rubbing issues?
  6. rabs
    rabs Revo
    101
    Yes it did rub on back straight away, seen other posts about removing screw under arch so that has been removed and replaced with smaller screw but have not tested yet
  7. dipstic
    dipstic Member
    384
    Just doing the maths
    Offset of 48 (std on S3 is 54) thats difference of 6mm +1/2 j (8.5j against std 8j) 12.5mm + 6mm= 18.5mm further out than std + 235 tyres which are about right for 8.5 rim width.
    Most wheel sellers quote for 19" wheels an offset of 43mm,45mm,47mm most also quote 235 tyres although I have seen 215 offered (stretched look)
    Would be interesting to get some consistant figures on what fits without rubbing.
    Thats also without taking in the effect of lowering (In theory lowering with uprated shocks and uprated anti roll bars will reduce body roll etc so possibly help to reduce rubbing issues).
    But lowering with springs on their own should make it worse.
    So would be very interested in your rubbing issues if any.
    Might be worth making a sticky of std offsets for various wheels and models and a list of what wheel/tyre combinations people have fitted and any rubbing issues.
  8. John @ DW
    John @ DW Member
    300
    On the A3 we have always stuck with a 225/35/19, I have that size on my 3 door on 8J with at ET50 and I never have any rubbing, plus it has been lowered 30mm. The original offset for the 7.5x18s is 56mm, so with the 8.5 and ET48 there will be 5mm less clearance on the inside.
  9. dipstic
    dipstic Member
    384
    So its always best to keep as near as possible to oe offset,
    7.5x18 is 56mm
    8.5 x19 et 48mm
    Correct me if im wrong (getting old here so memory not as good as it used to be)
    48mm as opposed to 56mm will mean the wheel will sit out (away from the suspension leg) by the difference ie 8mm (offset is measured from the wheel mounting flange/face)
    The different in wheels width in this case (7.5j/8.5j sure 1j= 25mm)
    So therefore 1j wider 25mm + 8mm = 8mm further out from the suspension leg than the OE wheel (or outside edge of rim 33mm nearer the arch lip)
    Or have I got it all wrong?
    Good info anyway,food for thought.
    Many thanks:icon_thumright:
  10. -Ju-
    -Ju- Well-Known Member Team Panther VCDS Map User Audi S3
    2,289
    438
    Surely if the rim is an 8.5j instead of a 7.5j, that's a difference of 25mm overall. That would make it 12.5mm either way from the centre of the wheel so the effect on the offset would be 20.5mm (12.5mm + 8mm)
    Both sets of my genuine A3 rims are 7.5j x ET54 offsets. I think the ET48 offset originates from the A6, I maybe wrong though.
  11. rabs
    rabs Revo
    101
    yes indeed from the A6
    Standard 7.5J ET56
    8.5J * 19 ET48 = 5mm closer to inner arch and 21mm closer to outer arch
    8.5J * 19 ET43 = same distance to inner arch and 26mm closer to outer arch
    Hope this helps
  12. N8
    17,163
    718
    Maars isn't gonna be happy, your A3s look identical now! Looking nice though, can't wait to get my 19"s on now. With ET45 I don't reckon I'm gonna need spacers. Where in the south west are you based?
  13. si_reading
    si_reading Member
    168
    Looks smart mate. I do like those rims.
  14. Matt
    Matt Active Member
    1,404
    Very nice. I would love some 19" BBS CH Black Editions with a similar drop on mine. Just remembering how unforgiving the ride was on a previous modified car puts me off though!
    What is the ride like....?
  15. N8
    17,163
    718
    Well get some coilovers and it will be smooth smooth smooth matt
  16. rabs
    rabs Revo
    101
    The ride was better with the H&R fitted with standard rims. Now the 19" are fitted it is harder for sure but not as bad as i expected. Will report further once i have done a long run.
  17. rabs
    rabs Revo
    101
    I spoke with Maars about 3 weeks ago and he is cool with it.
    I am in Bristol.
  18. N8
    17,163
    718
    Excellent rabs, thats where I'm from. What part of bristol, when I come down in may, we'll have to meet up! Car is looking very nice though....nice to see more people on this forum going down the 19" route...
  19. rabs
    rabs Revo
    101
    Live 5 mins from Almonsdbury Interchange.
    I will sort your Remp out for you when your down ;-)
  20. N8
    17,163
    718
    Well your in luck because I want a Revo map! Not till the summer though, June times.
  21. maars
    maars Full speed ahead
    576
    Hey I'm cool - they're great wheels and it's nice to see them on another car :salute: Here's a phone camera shot of mine...
    ...on 225s and a 45mm drop on H&Rs (no rubbing!)
    The 235s look better as on mine the rim sits proud of the tyre so the tyre offers zero protection from kerbing. But the rolling diameter is correct with 225s - ok it's 1.5% out with 235s but I wanted to get the closest match to the outgoing 18s I had on.
    Loving the H&Rs too, and the 19s :thumbsup:
  22. N8
    17,163
    718
    Glad to see you read my message! 1.5% isn't really alot though is it James? U need to take some better pictures and clean it properly!!!
    235s here we come..
  23. rabs
    rabs Revo
    101
    Been on a few good runs this weekend and the wheels do not rub at all....Happy Days
  24. N8
    17,163
    718
    Good to know! Car still looking nice and clean rabs :thumbsup:
  25. rabs
    rabs Revo
    101
    Not to bad, wheels are looking a little dirty and i am not looking forward to cleaning them.
  26. N8
    17,163
    718
    Make u invest in some nice wheels brushes!
