GUTTED.com.
g60leigh Dec 21, 2012
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Just been out (in the rain) and fitted my shiny new Brembo's
    Well one side at least. All went well up until the point I went to fit my ****ty 18" alloys to find the spokes catch the brakes. Stupid dish!
    Totally gutted now.
    Does anyone know if standard S3 Avus alloys fit over LCR Brembo's?
    If so is anyone selling any or wants to loan me some?
  2. Sam_
    Sam_ Down under
    3,038
    480
    I know the feeling. I had to use spacers to fit my CHs over the Cayenne/GT2 6 pots.
  3. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,146
    1,983
  4. g60leigh
    1,674
    207
    Don't I feel like an ar$e!!
    I have spacers in the garage.
  5. Prawn
    11,468
    3,359
    standard Avus wheels clear the brembos just fine mate :)
    Many deep dish wheels won't though, as to get the offset and the dish, the spokes are quite far back from the rim edge, meaning poor brake clearance.
  6. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    I love this reply.
    Bad luck dude, they looked so good too!
  7. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    196
    How you get on with spacers......?
  8. g60leigh
    1,674
    207
    I haven't been back to it yet.
    Late night mechanics I think.
    Any volunteers to help lol.
  9. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    I can confirm the 17" Avus wheels fit with LCR Brembo's
  10. g60leigh
    1,674
    207
    Just to throw another spanner in the works.
    I have a B5 two piece disc set up. So have the 3mm spacer on the callipers.
    Does anyone know if the standard Avus will fit over still?
    Hoping Bill or Tuffty pop up lol.
  11. s33nyboy12
    1,484
    196
    Your a bit far from Nottingham otherwise I would help..........
  12. g60leigh
    1,674
    207
    Cheers bud. Yeah just a little far.
  13. Prawn
    11,468
    3,359
    Yes they'll still fit fine :)
  14. <tuffty/>
    21,016
    3,780
    ^^^^ what Prawn said...
    I have 10mm spacers on the front for my RSTT's to clear the AP calipers I have
  15. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    Wish I'd of seen this earlier mate, I would of come to help.
    Iv already had a drink and have planed the night with the better half.
    Should drop me a message of you ever need a hand, I'm not the greatest of help but still better than nothing.
  16. g60leigh
    1,674
    207
    Cheers Prawn and Tuffty.
    Just what I was hoping to hear.
    Get baby to bed snd I'm going back out to have another go at it.
  17. g60leigh
    1,674
    207
    No prob coatsey.
    May be still at it tomorrow lol.
  18. g60leigh
    1,674
    207
    Spacers worked a treat.
    Still have to bleed them and sort the pad wear indicator as the LCR pads don't have one fitted.
    Do that all in the morning as can't fire up the compressor now for the bleeder.
  19. Sam_
    Sam_ Down under
    3,038
    480
    Haha why? I had the same experience fitting my brakes? Does Tuffty's reply also get you going ;)
  20. g60leigh
    1,674
    207
    Fitted and waiting to be bled
  21. g60leigh
    1,674
    207
    These continue to fight me.
    Got it all bled and car back together.
    Pedal travel is to long. Brakes work great though.
    And have an annoying wub wub wub sound at low speed.
    So gotta have another look. Not sure if the back plate is catching slightly or wheel is not spot on straight due to spacer.
    Or could it just be the brakes need to bed in?
  22. 16Klappe
    5,795
    1,184
    Second hand discs? Could be warped.
  23. Prawn
    11,468
    3,359
    you'll often get debris build up around the edges of the discs causing a bit of a rub at low speeds at first, I woudln't worry about that bit.
    Long pedal travel is most likely the bleeding stilll I'm afraid mate.
    How did you bleed them? When I do mine, I bleed through the outer most nipple first, then the inner one, then back to the outer one for a final bleed.
    When you'ce done both sides (I do the pass side first as it's furthest away from the MC), bleed the master cylinder as well on both nipples.
    MC bleed is usually what restores pedal feel. Be careful with driving it with a low pedal as you can damage the MC
  24. g60leigh
    1,674
    207
    Used a suction bleeder attached to my compressor. Pulled fresh fluid through all the lines. (Made sure reservoir didn't empty)
    Started back passengers side
    Back drivers side
    Front passengers
    Front drivers.
    Did furthest nipple on brembo on each front first.
    Got no bubbles coming through when finished.
    Is master cylinder bleed difficult?
  25. Sam_
    Sam_ Down under
    3,038
    480
    And you kept the MC topped up throughout the process? That's pretty key to making sure no air gets into the system, else it's a right ball ache apparently (not happened to me).
    Edit: Just read your last post. Maybe try another bleed. I probably used almost 500-750ml bleeding my fronts making sure it had fresh fluid from MC to calipers.
  26. Prawn
    11,468
    3,359
    if you've not bled the master cylinder, you're wasting your time dude.
    It's essential to getting a good pedal feel.
  27. Sam_
    Sam_ Down under
    3,038
    480
    But wasn't for me :) Why would it need bleeding if you keep the reservoir topped up.
    I totally went against the AS grain, I pedal bled, fitted 6 pots, and have a better than OEM pedal feel. It's crazy ;)
  28. g60leigh
    1,674
    207
    Nope didn't bleed the MC. Dohhhh...
    Any guides on here how to do it? Or is it as simple as doing the brakes?
    Will I need to re bleed brakes after?
    Wish I could afford to pay someone else to do this for me lol.
  29. Prawn
    11,468
    3,359
    undo the two nipples, let fluid out!
    sIMPLES.
  30. ReDBull
    ReDBull Member
    217
    13
    I didn't bleed the MS either and haven't had problems? LCR calipers are a PITA to find wheels that fit.
  31. g60leigh
    1,674
    207
    Sorry to sound a simpleton
    Literally undo the nipples or run the vacuum bleeder on it too?
    Thanks for all the help.
  32. g60leigh
    1,674
    207
    All sorted now and damn does it stop!!!
    It was just a bit of air in the master cylinder.
    Not too bad a job to do. Just took off charge pipe to get space to work.
    7mm socket on the nipples (pre-soaked in penetrating fluid) and give the brake fluid a pull through with the vacuum bleeder.
    Thank you for all the help once again guys.
  33. mrfaststu
    mrfaststu Member
    35
    i got a set of avus wheels and tyres if you interested
  34. g60leigh
    1,674
    207
    Yeah mate if price is right. I have PM'd you.
