Gunky oil cap?!?
s3mike Mar 20, 2008
  1. s3mike
    s3mike Member
    240
    I've noticed in the past couple of weeks that the oil filler cap on my S3 has white deposits on it. I know that this is normally the sign of head gasket issues but I've also heard it can be caused by short journies in cold weather ( condensation mixing with the oil ? )
    My car has used no oil or coolant since new and it runs fine. Could the deposits be a symptom of my 7/8 mile town journey to work and cold weather?
    There is no gunk or deposits on the dipstick or in the engine ( what I can see from the oil filler cap ), it's purely on the underside of the oil cap.
    Anyone else had this?
  2. newbiecrg
    newbiecrg windsurfer
    1,328
    Mine is ok... but it is staying in warmer weather and never does less than a 20 mile trip... and does lots of motorway...
    Pedro
  3. phantom
    phantom On Boost
    1,750
    Mines fine mate , i would think 7/8 mile is a decent trip , it's not as if your driving it and the car never gets up to temp?
    leon
  4. daviscup
    daviscup Member
    134
    Yeah checked my oil at weekend and found a bit of white gunk under my cap too. Thought it was a bit strange, but car still has lots of warranty so not too worried.
  5. s3mike
    s3mike Member
    240
    That's true, it does get up to temp and the oil temp usually gets up to 80 or 90.
    I can't understand where it's coming from if no coolant is disappearing though.
    Maybe I'll get the dealer to check - I can hear the response now though!!
  6. richjohnhughes
    richjohnhughes Member
    104
    check your coolant bottle also - if it contains some oil you have a issue.......otherwise, just short trips. clena it out and take for a long blast and then check again.
  7. s3mike
    s3mike Member
    240
    Thanks for the replies guys.
    I'll have a play on the weekend and see if it goes away on longer journeys.
  8. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    unlikely its the head gasket, its condensation.
    Take the car on a good run of say 100 miles and get it nice and hot, the water will turn to steam and disappear.
  9. golf
    golf ***** rent boy VCDS Map User
    1,556
    I'd be very, very surprised if it was the head gasket on such a new car.
    It's more a case of the oil hasn't reached full operating temperature and as a result you see the condensation under the cap. It needs a decent long run to clear up the cobwebs, take it for a drive on the motorway and I'm certain you'll find the cap clean as a whistle.
  10. phantom
    phantom On Boost
    1,750
    I'm only doing very short trips in mine ATM , but when it's up to temp i do give it a GOOD HIDING :asskicking: The S3 loves being driven hard!
    p
  11. s3mike
    s3mike Member
    240
    I'll give it some stick on the way home.
    Only problem is I run out of road too fast!
  12. phantom
    phantom On Boost
    1,750
    If you don't have the space to open it up, just keep it in a lower gear , drive in second and third , instead of third and fouth.
    Give the engaine some load to deal with! Not good for your MPG, but good for the car. lol
    p
  13. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,487
    Just checked and I have white deposits too. I do a lot of short journeys though so for once I'm not too concerned (with fingers tightly crossed).
  14. s3mike
    s3mike Member
    240
    I had a thrash on a deserted road near me and got the oil temp up to 99 degrees.
    Checked under the cap when I got back and no more white stuff.
    Doesn't look like it's anything to worry about.
  15. phantom
    phantom On Boost
    1,750
    Good stuff, we have a sporty car , it's made to be driven hard-ish so enjoy it!
    p
  16. newbiecrg
    1,328
    yeap... mine sometimes oil temp reaches 104... the car seems to like being revved..
    Pedro
  17. MatLamont
    MatLamont Member
    i had the same problem, i took it to a garage they said it was fine. i checked a week later it was worse. it turned out my engine was full of water lol! so i had a second hand engine put in. Under warranty of course :)
