Guide to retrofit OEM Bluetooth with RNS-E
jasonc Feb 18, 2012
  1. jasonc
    jasonc Active Member Audi S3
    256
    Hi All,
    I spent a good chunk of today messing about retrofitting an OEM Bluetooth kit into my S3 Sportback (8P Facelift 58 plate) so thought I'd share the experience since judging by the number of posts on here this is a pretty popular thing to do.
    I bought a new OEM kit from eBay for 250 quid which came with the bluetooth module, wiring loom, microphone and antenna.
    I did my homework in advance and read everything I could find on this fine forum relating to Bluetooth. I found a lot of useful tips on here so thanks to everybody who has previously discussed the subject and answered other peoples questions since it all helped.
    What I couldn't find anywhere was a proper guide or much in the way of pictures so thought I'd knock one up since it may come in handy for others attempting the fit.
    The main issue that I had was with the location of the bluetooth module - the correct location (as many have previously stated) is under the passenger seat but this seems to involve taking up the carpet which I didn't want to do so I abandoned that idea.
    Eventually I managed to fit it in the radio compartment behind the RNS-E which seems like a pretty sensible location to me.
    I make no guarantees that any of my methods are correct but it's all gone in neatly and works perfectly. I reckon with the guide anybody should be able to do this in 1-2 hours. Considering the going rate round my way seems to be 450 quid to supply and fit I'm pretty happy with that!
    There are a lot of pictures in here so I'd thought it best to PDF the thing to keep it all together:
    http://dl.dropbox.com/u/10357287/guides/Retrofit Audi OEM Bluetooth.pdf
    Hope it comes in handy for someone even if just for the pictures!
    Veef13, mister.c. and voorhees like this.
  2. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    Good work mate.
    I definitely agree with the location of the Bluetooth module.
    I tried to get mine behind the Stereo like you have but it simply wouldnt fit.. I wonder if the facelift CC unit is slimmer??
    I have stored mine, and my customers, in a fixed and secure location behind the glovebox.
  3. NKenny
    NKenny Member
    42
    Nice one, thanks. I have been considering installing an OEM bluetooth kit but the lack of insructions/guide put me off.
  4. paultaylor
    paultaylor Member
    294
    very good guide, I might move my BT from under the glovebox to the location you used once i get my RNS e
  5. jasonc
    256
    The CC unit in the older cars would need to be a LOT bigger to get in the way - on mine its a pretty slim unit with loads of space behind it. It's only the business card holder which goes all the way to the back and gets in the way. If it wasn't for the antenna sticking out so far I reckon I could have fitted the BT module horizontally behind the climate controls and underneath the business card holder (if the antenna had a right-angled connector this could be done). It's possible that something else has changed about the design of the dash which stops it fitting in older models.
  6. jb0o
    2,664
    118
    I'll have to have a second look at that then.
    Id much prefer it to be stored behind the stereo, just makes sense really and improves access to the module as well.
  7. A3-8PA
    A3-8PA Member
    107
    Hi, I m after bluetooth module part number... Already got latest RNS-E in my audi A3 - 2008..
  8. jb0o
    2,664
    118
    Latest BT module is 8P1 862 335
  9. gary3306
    gary3306 Active Member
    989
    41
    Just clear them faults that come up now. They should disappear if everything is working right now. Great guide, well done mate. I'd be doing that myself but the car already had it :cool:
  10. 5ean
    5ean S3 Owner VCDS Map User
    415
    Good guide mate, i take it the wiring loom you got with the bluetooth didnt need splicing in to the current loom?
  11. jasonc
    256
    No - it just plugged straight in and sits in line with the existing cable from the car to the RNS-E.
  12. NHN
    29,551
    1,777
    I'd never stick it anywhere but under the seat, the oem pcb antenna type is very delicate, in 99% of cases you'd never have to get to it unless it was faulty & these are fairly solid units & dont often go wrong.
  13. N8
    17,163
    719
    All about 8P1 Bluetooth, fitted OEM under the seat :wub:
  14. dk1234
    dk1234 Member
    215
    Nice guide, these are the kind of guides I like to see..... pictures are worth a thosand words. I hope more people post guides like you. I would think about doing this to replace a old car phone system (Nokia 810) that came in my car when I bought it that I've never used.
    I got an 2004 A3 fsi with an mk1 RNSe (I assume, as it takes upto 4gb sd cards), would I still have to get it coded and are there other places other than Audi where you could get it coded with the VCDS?
    I assume that even though my car is alot older it shouldnt be massively different should it?
  15. NHN
    29,551
    1,777
    Yes vcds can code it, whereabouts are you located?
  16. dk1234
    dk1234 Member
    215
    I'm in Tottenham, North London. How much would it be if I were to get that done?
  17. NHN
    29,551
    1,777
    I know of someone who could just code it in your area for a small price, if you wanted the full install, then best to PM me for a price as I do supply/fit.
  18. ianleon
    ianleon New Member
    What does the letter mean on the end of the part number of the bluetooth unit ?
  19. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Just a different revision ie, the greater the letter, the newer the unit
    Of course 8P1 862 335 (no suffix) being the newest of the lot
    While we're on the subject of Bluetooth modules - Jonny or Nigel, could you pm me prices for a decent module?
    Not too old and preferably not a flashed unit ;)
    Doesn't have to be brand new, infact the cheaper the better :)
  20. cboy
    cboy Member
    66
    ive just bought a 2011 a3 s line which module would be ok for mine?
  21. Lukeyb
    Lukeyb Active Member
    397
    53
    I have a '10 rnse with an '07 H revision (iirc) Bluetooth unit. So I'd say at least an '07 or newer will work.
  22. Anthony090
    Anthony090 New Member
    Hi Mate,
    I am having a similar issue, i cannot fit it behind the stereo, i have tried every angle, would you mind telling me how you fitted it behind your glovebox?
  23. kico18
    kico18 New Member
    Hi guys, i just bought my Bluetooth module (original) to connect with my RSN e. Can someone please put some guidelines please. Thanks
